  • Replies 50
  • 1 month later...
hmmm anyone here with a GTS4 had a problem with there AWD light? ive only ever had it turn off twice now and the SLIP light come on as usual, but will go back to normal.
The AWD light also flashes a bit on start up and i can hear a buzzing in the boot like its trying to connect. mabey its a connection problem but ive had it looked at a few times and no one can find the problem, the AWD is working as far as i know, tho i would still like to fix the problem.
Also, o0skyline0o, Do you still have any of thoes parts form you 5 stud conversion left? Better ask now that ive got the money haha. im in sydeny aswell so pick up is no problem.
ATTESA Codes - R33 Regular and Vspec
1,5 - Front right wheel sensor and circuit
2,6 - Front left wheel sensor and circuit
3,7 - Rear right wheel sensor and circuit
4,8 - Rear left whel sensor and circuit
11,21 - Front right inlet solenoid valve and circuit
12,22 - Front left inlet solenoid valve and circuit
13,23 - Rear inlet solenoid valve and circuit
15,25 - Front right outlet solenoid valve and circuit
16,26 - Front left outlet solenoid valve and circuit
17,27 - Rear outlet solenoid valve and circuit
31,32,33 - E-TS solenoid and circuit
34,35,36 - E-TS fail safe solenoid and circuit
41,42 - ABS actuator relay and circuit
43,44 - ABS actuator motor , motor relay and circuit
45,46,77 - ET-S/ABS control unit ground and circuit
47,48 - E-TS/ABS control unit power supply and circuit
51,52 - E-TS actuator motor and circuit
53,54 - Pressure switch and circuit
55 - Air bleed switch and circuit
56 - E-TS oil level switch and circuit
61 - FR and RR G sensor 1 and circuit
62 - FR and RR G sensor 2 and circuit
63 - FR and RR G sensor 1 or 2 and circuit
64 - G sensor 1 power supply and circuit
65 - G- sensor 2 power supply and circuit
66 - Side G sensor and circuit
75 - Throttle position sensor and circuit and sensor
Are you sure that is what you are getting?
Also the buzzing in the boot, sure its not the fuel pump? The only part that would make a buzzing noise around that area is the actuator for pumping the Matic-D around the diff and transfer case. Its a $4500 part that rarely breaks so i wouldnt worry.
You should get the system COMPLEATLY bleed the propper way and then new fluid in there to eliminate that option.
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
