  • Replies 50
  • 1 month later...
hmmm anyone here with a GTS4 had a problem with there AWD light? ive only ever had it turn off twice now and the SLIP light come on as usual, but will go back to normal.
The AWD light also flashes a bit on start up and i can hear a buzzing in the boot like its trying to connect. mabey its a connection problem but ive had it looked at a few times and no one can find the problem, the AWD is working as far as i know, tho i would still like to fix the problem.
Also, o0skyline0o, Do you still have any of thoes parts form you 5 stud conversion left? Better ask now that ive got the money haha. im in sydeny aswell so pick up is no problem.
ATTESA Codes - R33 Regular and Vspec
1,5 - Front right wheel sensor and circuit
2,6 - Front left wheel sensor and circuit
3,7 - Rear right wheel sensor and circuit
4,8 - Rear left whel sensor and circuit
11,21 - Front right inlet solenoid valve and circuit
12,22 - Front left inlet solenoid valve and circuit
13,23 - Rear inlet solenoid valve and circuit
15,25 - Front right outlet solenoid valve and circuit
16,26 - Front left outlet solenoid valve and circuit
17,27 - Rear outlet solenoid valve and circuit
31,32,33 - E-TS solenoid and circuit
34,35,36 - E-TS fail safe solenoid and circuit
41,42 - ABS actuator relay and circuit
43,44 - ABS actuator motor , motor relay and circuit
45,46,77 - ET-S/ABS control unit ground and circuit
47,48 - E-TS/ABS control unit power supply and circuit
51,52 - E-TS actuator motor and circuit
53,54 - Pressure switch and circuit
55 - Air bleed switch and circuit
56 - E-TS oil level switch and circuit
61 - FR and RR G sensor 1 and circuit
62 - FR and RR G sensor 2 and circuit
63 - FR and RR G sensor 1 or 2 and circuit
64 - G sensor 1 power supply and circuit
65 - G- sensor 2 power supply and circuit
66 - Side G sensor and circuit
75 - Throttle position sensor and circuit and sensor
Are you sure that is what you are getting?
Also the buzzing in the boot, sure its not the fuel pump? The only part that would make a buzzing noise around that area is the actuator for pumping the Matic-D around the diff and transfer case. Its a $4500 part that rarely breaks so i wouldnt worry.
You should get the system COMPLEATLY bleed the propper way and then new fluid in there to eliminate that option.
