i hate road rage, i hate any rage.... anger is such a waste of energy... you are insignificant in this world... you are worth no more or no less than any other being on this planet. these people that think they are more important, therefore need to harass people on the roads or get angry over a little thing so much as a little mistake that held them up for 2 seconds
disgust me.. there is no such thing as human decency anymore... everything thinks they are more important and their journey cannot be held up.
  • Replies 84
depends on the circumstances...
for example, if sum1 did sumtin 2 me wether it be on the roads or elsewhere that jeopardised my safety, my belongings that ive worked hard for or anything like that outta their sheer incompetence... then id feel a certain amount of rage! lol... maybe not so much for being held up cause they are driving cautious lol...
but for instance if sum1 merged into the side of my car doin 110 cause they didnt check their blindspot, n put me into the wall n i was paralised for the rest of my life id be :(:):yes::/:down::D:rant: :rant:
^^^ Grafton huh?
How far is that from Byron B. or Nimbin? Makes one wonder what he used for tea leaves in a "pot 'o tea" - or his "coffee" had coke beans instead of cocoa beans > PSYCHOTIC
Not far away, wasn't the typically peace out type from the hills but more the angry burbon drinking dick bikie want to be.
Matt
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
