Topic: Ec Twilight 17.02.10 - $1200 Worth Of Prize Money, Timing, Drinks And More...
Hey All,
The EC Twilight events have become of interest of late and just wanted to give you a heads up on an event on the 17th Feb
$1,200 of prizes on the table from RDA, EBC and Sureflo Perfromane Exhaust (and no i do not work for any of those companies) for things like fastest lap and specific classes - coupe, sedan, hatch, etc.
More information is on the epcc.net.au website.
Have some friends which drive in the series and with it now open to JDM and Aussie cars should be really exciting this year – from behind the steering wheel or from both pit wall :huh:
White_Skyline
If you just want the track time (without the EPCC stuff), it is $295 to book it through Circuit Club.
I'm thinking about it, I've never had a proper run on EC.
$345 entry????
Yes its $345...those JPM photo's you get included are expensive apparently.
Also Kumho and FSport are sponsoring the series too - which means 10% off all tyres / race seats / suits / helmets and they are also putting down $200 for one of the classes at each event - prize pool is now up to $1400 :P (from looking on the site)
So if my maths isn't out - max you could win on the day is $600?
Not a bad day at the office if you have some car control skills :D
Edited by white_skyline
Not a bad day at the office if you have some car control skills :)
hahah thats why I wont be going :bomb_ie::D
nah I'll keep an eye on it, and see what the class I would fall into goes. If I even have half a chance i'll give it a go :D
there going to be more of them throughout the year?
club supersprint is $180
Eastern Creek also has private practice for L2S also if you want plain vanilla track time:
Friday 5th February
Saturday 6th March
Friday 12th March
Friday 16th April
Friday 28th May
Friday 18th June
Friday 2nd July
Friday 6th August
Friday 22nd October
Friday 29th October
Friday 19th November
$95 for ARDC members and $125 for non-members
Edited by LSX-438
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
