what car
87 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Well i have been considering purchasing a 180 or a s14 for a while now (none on the market the suit my taste/buget atm)
The 180sx is lighter then the s14 but just but the s14 dose have a wider width which would be better on the track not sure if it would be better for drifting the s14 dose have
VCT but apparently VCT die pretty quickly leaving u with a tapping noise on idle personally the 180sx look much better than s14's i think any way . The s14 has better brakes
then the 180sx and has 5 stud and what i read on these forums is that a slightly modified sr20 can keep up 2 a slightly modified r33.
sr20 vs the rb20 im not sure if the rb20 has oil surge (Can some 1 clarify if rb20 have oil surge issues ??) issues like the rb25/26 but i know that rb20 are pretty tough but then again the sr20 are strong to.
The s14s came ADM so im pretty sure that insurance will be cheaper than a JDM can some 1 confirm?
The wise choice would be the s14 and it has better brakes .. etc but the 180sx looks are much better.
  • Replies 41
JDM vs ADM for insurance costs isn't really much worth taking into account unless your over 25. Reason is there are many places that will not insure imports at all and they are likely to have cheaper insurance premiums. On the other hand if your under 25 in a turbo car they won't insure you anyway
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
