Which elbow - The intake after cooler you mean?
Or the intake to the turbo?
You shouldn't have an issue with any bolt on type turbo's.
Few people running around IIRC with 280rwkw through stock after-cooler piping (using factory return/flow style cooler setups)
Before turbo however you might need a metal pipe, there are some DIY posts in the Fab/DIY area, often it can suck closed once you upgrade turbo :D
https://www.sau.com.au/forums/topic/303757-how-much-hp/#findComment-5032843
There is no point upgrading turbo, and using the factory dump of the R34 GT-T - it's as simple as that mate.
It's not a question of damage, its a question of doing it correctly.
The added back pressure is going to cause added heat & stress on the motor, turbo and all things concerned. Add to the fact backpressure will limit power output and increase missfiring/detonation.
Change it.
https://www.sau.com.au/forums/topic/303757-how-much-hp/#findComment-5032987
