  • Replies 846
Posted Images
Awesome to see such big numbers already. Its gearing up to be a great day. :banana:
Hope to have that brake upgrade on the Stagea done before this day (can't imagine why it wouldn't be done by then) ... as taking my race bike would be frowned upon :P
I'm down like a clown, as is 4DR_Taxi_Man (Adrian) and BENDERS32 (Ben)
I have all the cash here and waiting for the deposit and SA membership here for all 3 of us.
HESLO, I have sent you a PM. Please give me a ring in the morning.
Edited by BIT SUS
keep my spot
$45 money order being posted today (thurs 14 jan) to the nominated address on the sausa application form
$100 ready to be deposited into account for my spot
hoping my rb26dett track car will be ready (finances permitting; ie tuneup) enough for its 1st outing
Im sure it will, ku36 kuhmo tyres are the biggest cost for me after the $1.25 roll cage (true!!!!)
if not, stagea it will be :banana:
this is a great idea, cant wait to be involved in one of these and meet everybody, will be nice to do a SAUsa track day, it will be more friend orientated than a normal one. Also i have been meaning to get membership for a long time how do i go about it, someone please PM me, thanks
Edited by ON EDGE
Here ya go mate http://www.skylinesaustralia.com/forums/Sa...on-t296574.html
ITs my understanding that this is an SAUSA event, preference WILL be given to members first, then open to non members. Heslo/Shane will confirm
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
