Sausa Track Day #1
heslo
 Share
  • Replies 846
Posted Images
ah kool not sure who you are exactly but thats kool we'll meet up
you wouldnt, ive never been to a SAU event, been meaning to but always clashes with work etc. but hopefully this time ill be able to get out there
i dont have time to reply to each and every responce but this is the jist of how we sort out who goes
Members that is paid club members get priority
Club sponsor's get further priority over members
after the date that Heslo specified if there are any remaining spots they will be opened up for the general public
i have just gotten off the phone from Luke and i am quiet excited to say the Skylines Australia : SA will be raffling off 1 spot to anyone not just paid members
this raffle will be held at the SA Simulation day further information as its recieved
I'm in if there's spots hopefully, already member
Got a feeling that ain't going to count for shit!
well you would better hope that it does count for something Steve....otherwise its just useless becoming a member in the first place :(
Ok so more information about this raffle
$5 per ticket and that gives you the chance to win your track day free of charge SAU. Sa will pick up the bill for your entry, this is open to everyone buy as many tickets as you like raffle is open from now until 8.15 on the night of the simulation event and the winner will be drawn after the trophy presentation on the night
Please be patient guys myself and heslo dont have jobs at computers so you only get limited information during the day
Members get priority i dont think this needs to be repeated again the length of your membership doesn't matter join today and pay your money first and your spot is secured thats the fairest we can do it
sorry but I think people who have already paid should be getting preference over 'payment pending' people and non members.
my 2c
-D
i agree with dohmar.
i was chasing cash from people and still chasing and then had ppl pull out and no one to replace..
so i think that if ppl pay now there in no matter what..
last thing u want is all these ppl saying yes ill be there then not pay or show..
happened to me and i had to foot the bill..
but if tell me now if im not in coz i will get my money back off damo and organise my own..
cheers
my 2c
-D
hang on a sec
Ive been here on SAU for 5yrs now, very active
I havent been able to afford membership simply because of finances (not working)...
however this track day marks the ideal time for me to officially join the club; not that I can really afford it until bike & daewoo sell,
but nevertheless, payment & membership form sent via post
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
