Sausa Track Day #1
heslo
 Share
What date exactly is the deposit due?
The total cost for the day will be $200 PLUS an extra $25 if you don't have a CAMS license because you WILL need one. Application is available on the day so there's no worries there, just make sure you have the green stuff in hand :happy: Spots are first for SAUSA members, then the rest to the general public so join up if you aren't one, it's only $45. Deposits will be needed as we need to secure the track, this will be half of the full amount (so $100) and will need to be payable by March 1st. The remainder must come in the following weeks.
BTW - Can I get some official notification that my full payment of $200 made on January 15, 2010, was received?
  • Replies 846
Posted Images
Did you pay via direct debit David? I'm going to the bank tomorrow for a printed statement, so I'll reconcile your payment and confirm with Luke.
That goes for everyone else. If you paid via direct debit with your username as reference, I'll pick it up.
:happy:
Was just about to PM you about that Ruby but you saved me the hassle :P Let me know who's paid and who hasn't and I'll update this thread
There's me for starters $100 deposit. I'll update you on the rest tomorrow.
Luke,
Got the statement today. I'll scan thru it after work and give you the list.
David,
I can confirm your full payment of $200 has been received. :D
Hi,
paid in full today, the reference is 0402565077 because
the bank lady said i couldn't put a letters as a reference?
Cheers Bengi
No worries mate. I'll match your payment and mark your full payment on the list.
:P
There's only a few weeks left for you to get your deposits in. If you don't get in before the 1st of March, it becomes first come first serve basis so make sure you pay before the deadline :P
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
