Sausa Track Day #1
heslo
 Share
  • Replies 846
Posted Images
hahaha that would be great Mark can at least bring the R down for some showoffski
haha yeah mate there is alot to show off :domokun: done and done mate ill book it off tomorrow when im at work.. just the whole being with people with similar passions will be great hardly seen anyone in the 8 months that my car has been off the road... :)
dont chad! show em what ya made of :thumbsup:
OK MY CAR WILL BE READY BY THIS DATE CAN MODS/ORGANISERS PLEASE NOTE ! IF THERE IS A POSITION AVAILABLE SURE THOSE WHO WERE IN FIRST THEN PLEASE NOTIFY ME AS ILL PAY FOR CLUB MEMBERSHIP AND TRACK DAY FEES THAT NIGHT
a big thanks in advance.. ill also book this day off anyway so i can come down and support everyone and catch up with everybody ive missed..
LOUD NOISES :blush:
Cmon Jenkies, fill the club app form out now, youll reap the benefits.
LOUD NOISES :)
ok damo done and done. tel me how to get the ball rolling cos after a 12 hour day at work im too bloody lazy to figure it out :P
Luke and i have organised a John Bowe driving course for March 22 (http://www.skylinesaustralia.com/forums/Mallala-Trackday-March-t308433.html) that would be a great prelude to this April trackday.
If you want to brush up on your motorsport skills or would like a turn by turn breakdown of the circuit with input from professional driving instructors, then register here
See you guys out there in April otherwise!
btw, my full payment for this April trackday has been sent to the SAU account
Kim, I'll be getting Reuben to check the accounts and will update the list as soon as I have confirmed with him.
I definitely recommend the High Performance day that Kim posted above especially if you haven't been out before. You may think that $425 is a lot of money and you would be right but what you learn on the day is invaluable and will definately come in handy for our full blown track day in April :P
I definitely recommend the High Performance day that Kim posted above especially if you haven't been out before. You may think that $425 is a lot of money and you would be right but what you learn on the day is invaluable and will definately come in handy for our full blown track day in April :D
Luke PM sent with update
:P
Kim can you PM me to confirm when payment was made and the reference number used please. I have what looks like a full payment on a particular date, but the reference to the transaction doesn't identify who. PM sent about this too.
:P
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
