Sausa Track Day #1
heslo
 Share
I have had no fade at all with my 180sx running R33 GTS-t brakes and A1RM pads. This is doing constant mid 1:23 for 15 to 20 minutes.
Same here, 32 GTR brakes, 320kw, 1595kg car and 1.21 lap times and i've never not been able to pull up after the straight. I do have to push on the pedal as hard as i can to slow down after the straight but never run off the track and they last me for at least 2 track days and some street driving :( I will be trying the Race type pads for this track day so will be interesting to see how i go.
  • Replies 846
Posted Images
well cheers for the brake help guys, ill give them a go and see what happens.
and can i be put down for some timing as well? happy to pay the money as i would like to know an accurate (read: slow)time from the 31
Cheers Bengi
car is back from AM Performance and loving the work being done to it there.....now time to take it to boosty worx tomorrow and see what they can do....got braided brake lines with qfm a1rm's all around.....so car should be pretty much track ready by the end of this week :P
They can blow up your motor for free :)
Paid the remaining $100 in to the account. Paid in full. Received my helmet in the mail today via ebay, woop. Also received my a1rm brake pads the other day, woop woop
What you think of the helmet? Did you get it from this seller?, as that is what i am looking at getting.
/technical lesson :P
Technical Lession Fail.
mo·tor play_w2("M0442400") (momacr.gifprime.giftschwa.gifr)n.1. Something, such as a machine or an engine, that produces or imparts motion.2. A device that converts any form of energy into mechanical energy, especially an internal-combustion engine or an arrangement of coils and magnets that converts electric current into mechanical power.3. A motor vehicle, especially an automobile.
adj.1. Causing or producing motion: motor power.2. Driven by or having a motor.3. Of or for motors or motor vehicles
-D
Reuben has had to drop out. Spot is up for grabs and goes to Andz, check your PM mate
ops just got your message
will transfer full amount tomorrow at work (thurs)
cheers
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
