Sausa Track Day #1
heslo
 Share
going to see andrew at am performance this saturday and apart from that another quick check up on the dyno to see if everything is working fine.....and then the car is all ready to be tracked......
- braided brake lines fitted
- new clutch fitted and works awesomely lol
- new qfm a1rm's fitted with penrite sin 600 fluid $20/500ml
- oil cooler installed with a oil + filter changed
- leaks being sorted out now....1 down, 1 to go :(
  • Replies 846
Posted Images
car is at michaels for dump/front/decat.
intake pipe
screamer
then off to jeff on fri for tune at 21psi
then fit oil cooler and relo kit
oil change
hook up my defi sensors
new brake pads
then go fast!
well i am trialing the penrite sin 600 brake fluid for this track day and see how we go there......same with the qfm a1rm's.....got brand new tires on the rear so far fairly happy with them
good boy.
ive got it in the 200 at the moment... ill be switching to motul.
Should i do an oil change before the track day or after...or both?
Always do it before like dave said. I dont do it after, actually i'm still running the same oil i put in my car before Adrain's track day :cool:
Ok, cool. Would it be alright to change the oil 1 week before the event, drive on it a bit, and then do the trackday? Or would i be better off doing it 1-2 days before and doing very little driving on it?
Ok, i may do mine on the Sunday in the morning, then head out to Dion's place in the afternoon - as i am staying at his place the Sunday night as it is closer to leave from there, then Aldinga.
Oil change a week or so before is fine. Its the old oil that isn't great for your engine when it is under stress. The older the oil, the quicker it breaks down and then literally loses its lubricating properties. After a track day is a very good idea too - and if you think about it $70 - $100 to do them both is far cheaper than an engine rebuild.....
Very True...but i could have a lot of fun with an engine rebuild...however, i wouldn't like how much i would be spending.
Question, I may have a mate coming out to watch me make a fool of myself, would it be possible for him to drive my car out on the track if he has a helmet with no one else in the car? Or is there some insurance liability form i have to sign, that will stop him from being able too?
He would have to fill out the forms and pay $200 just like everyone else if there was a spot free.
EDIT: Beaten by Chad
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
