Sausa Track Day #1
heslo
 Share
  • Replies 846
Posted Images
If it is my turn in line - I guess I'll say yep.
:( will be there to see this thing in action again.... last time i saw this on the track it was like a limping t rex.... an animal pulling 1:14-1:16! but ive heard alot ahs changed!
Is it wrong for me to want 4 people to drop out so that I can see, hear and compare with Blue32's R32 GTR? :D
Jugs had to pull out of this event, just got the news now. Dohmar, you're up
EDIT: Dohmar said no, Blue32 is up
*sings*
"When you wish upon a starrrr,
Makes no difference who you arrrrrre" :banana:
hahaha itching to get on the track David
Definitely.
Considering going to the open day at Mallala on the 27th.
But I'm still dirty at Santa for not giving me a big brake upgrade kit. If only I could find $10k laying around.
Definitely.
arent we all.....i am trying to get everything sorted out before i fly to fiji at the end of march.....one month to do almost everything uummmm.....dont worry i will be back from fiji in time to have the 33 on the track.....
needs zorst, clutch, braided brake lines, servicing, diff
just need time and money
looking forward to this too!!
got some a1rm's fronts on the way, new swirl pot and pumps hopefully setup too, will be setting a lowish boost level and try do my best to stay out the way of you test pilots.
and he seemed so gung ho about it. what changed? oh well, for the better i spose, lookin forward to seeing more of blue32's impromptu barbecues! :D
and he seemed so gung ho about it. what changed? oh well, for the better i spose, lookin forward to seeing more of blue32's impromptu barbecues! :/
not having a job at the moment is a killer.
-D
Definitely.
yeah I recon lines have enough power and handling capabilities for the "Dustbowl" but braking is definitely an area that the Porsches have over us.
What?? I'm cooking the bbq?? :)
Ahhhhhh, thanks for offering Andrew :rofl:
-D
That's fine mate and completely understandable.....maybe next time. :)
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
