  • Replies 846
Posted Images
Hey Luke
Just wired through $200 to the account mate.
Description - Krishy Track Day
You guys should be able to get it by tomorrow.
Ruby can you please check that tomorrow and let me know via a PM.
Thanks
Krishy
what track pads should i buy for the 33 GTST? want to use em on the road too, have previously used s tune pads
Hey cosi mate i got QFM A1RM and they will do fine for both street and a bit of track work......you will also find a lot of people on here are using them....i paid $238 del for all 4 sets....of GSLrallysport (not too sure of the username) on here.....go back afew pages on here and you will find a link to him.....i just PMed him and customer service is very good
Fair enough Krishy. Have you used these pads at the track before though? or has anyone? whats the brake fade like?
Congratulations to David (writeoff) for winning the track day raffle. He will now participate at the low cost of $5. Mind boggling as to why more tickets didnt sell, even to those who had already paid and/or entered, surely the $5 gamble is worth saving hundreds.
Again, Congrats David from the exec :cheers:
Thanks Damo.
Congrats David have fun :D
Thanks Steve - it was the early positioning on the sim that resulted in the ticket being bought when it was. I was so hot after my run that I needed a drink. Only had a tenna so said that I'd grab a ticket as well. Worked out rather well for me :cool: and makes up for my poor times on the sim (although they would have been better if I hit the brake pedal instead of the clutch pedal).
want a spot... booked the day off :cool:
Speak to the execs as there was a spot reserved for the winning raffle ticket and I already had a place and had paid for it.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
