Reuben has had to drop out. Spot is up for grabs and goes to Andz, check your PM mate
Sorry fellas! Damn wildlife banged up my car a bit on a recent interstate drive :blink:
I'll still be there on the day to envy you guys. :down:
  • Replies 846
Posted Images
Hey Guys i have a proposal for you.
I spoke to Tristan Catford (GSR/EVO club president) and we can hire the timing gear that is used for the time attack. There are 12 units and the cost will be $500 for the whole set up. it works out to $42 per unit. These units will give you accurate timing down to the 100th of a second.
If two people who are in different groups want to share them then that is fine and it will make the cost $21 each, and i will swap them between the cars between sessions.
It really is only viable if ally units are spoken for.
I will do up a Propper timing sheet and will post that up if it goes ahead.
Just out of interest the cost of buying the timing setup is ~$6000.
I am definitely interested to have this and i dont mind paying $42 for it so that i can hogg it for the whole day :P
They can blow up your motor for free :D
ahahah +1 :laugh:
well they are only replacing my clutch and not touching any of the belts.....plus i am leaving work early and going to see it getting tuned.....love watching the car on the dyno being tuned.....also looking forward to driving it with a bit more power :D
What????? :P
It aint great havin a motor blown up for you, hope it doesnt happen to ya, but if it did you wouldnt want me to comment how you did
He already spun his bearing, i dont think anyones gonna be blowing his engine up soon :( Rebuild hopefully...
go the 26/30 steve, with a dry sump. you know u want to
-D
well they are only replacing my clutch and not touching any of the belts.....plus i am leaving work early and going to see it getting tuned.....love watching the car on the dyno being tuned.....also looking forward to driving it with a bit more power :(
its the final tune i'd be worried about :P
goodluck
go easy with the slagging of businesses guys....won't be the 1st nor the last shop that's had blow ups on dynos.
Best to keep that sort of thing to PM....last thing you need is a Process Server knocking on your front door.
well got the car back last night......the new clutch feels so damn different....the old clutch is what i would call it as FARKED......nothing left on it so no wonder it started slipping lol.....but i am suprised as to how long that lasted under decent thrashings.....oil cooler looks like its an awesome fit.....they only had to shorted one of the lines the rest were fine.....but no happy as there is still an exhaust leak which i will be taking the car back to AM to sort it out.....there is a boost leak as well.....so a few more things to be replaced and see if we can get a better result....making around 230rwkw but feels nice and responsive
ruby, sounds like u can help me be nige's pit crew then :P
Can do. :cool:
jk. sorry to hear about your car Ruby
Thankfully nothing major ... just a bit too risky for the track. Got most of the damage sorted now anyway.
I thought it was just a cracked front bar?
Edited by DSTROY
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
