  • Replies 846
Posted Images
if mine fits you can borrow mine for the day
thank you so much for the offer.
muchly appreciated - we'll be right tho - resoldering bits atm, fixed
found one of the 90mm q45 afm's is broken :down:
so currently soldering wiring plugs directly to stock r32 gtr afm's to make a flawless ecu-afm connection
weather aint looking good for this track day :devil:
might have to invest in some full-tread tyres
rain in Adelaide doesn't always affect Mallala so we should be ok. and "rain" in SA doesn't last for very long (10min?) - wait an hour and the track will be dry again :ph34r:
uh oh...
damn, Ive purchased a dodgy pair of Q45 air flow metres
just wont work no matter how its wired up.
the stocker gtr afms are cactus at the pinout point, might have to cut out the top and solder some wires directly to the connectors
if i cant fix it by mid week means I'll miss my dynotune session; therefore restricted to the stagea
grrr
If you've paid the $200 then yes, that's all that remains. And that gets paid on the day...
That reminds me, the following people have left to pay.
Dave - scandyflick (spoken to me)
Andrew - AMPerformance (money incoming)
Andrew - semislickR32
Martin - HOSTILE
Abe - Aberax (spoken to me)
Glenn - Heslos +1 (money incoming)
Adrian - 4dr Taxi Man (money incoming)
Adrian - rad32 (money incoming)
Do you want to borrow my GTR AFM's Brendan?
thanks so much for the offer
helps me out big time
Ive ordered 1x z32 afm, and will scavenge the z32 afm that is on my stagea and swap that with the working q45 afm.
that'll work
2x z32 afm's for the rb26, and 1x q45 afm for the rb25 (which is tuned via manifold air pressure anyways, afm is used via the piggy-back for voltage readings, clamped via a fuel cut defender)
well, for those thinking about breaking shit on the day, news is looking partly better
my winch is in ;)
now to get the tow hitch done and im set for full recoveries, even onto your hire trailer if need be :P
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
