  • Replies 846
Posted Images
If you've paid the $200 then yes, that's all that remains. And that gets paid on the day...
That reminds me, the following people have left to pay.
Dave - scandyflick (spoken to me)
Andrew - AMPerformance (money incoming)
Andrew - semislickR32
Martin - HOSTILE
Abe - Aberax (spoken to me)
Glenn - Heslos +1 (money incoming)
Adrian - 4dr Taxi Man (money incoming)
Adrian - rad32 (money incoming)
I don't recall having a conversation or sending a pm...unless of course you are talking about my post 1-2 pages back...ie this
Just sent the remaining $100, should be in the account on Thursday.
Martin - HOSTILE
semislickR32: Money Incoming. Finally! :D
ku36 are around $180 ea delivered from Option One garage, QLD, for 17x235's
They are on my track car ready and unused, as are the A1RM track pads, however I wont be able to bring the track car out
Will be in the stagea
KU36's are $275 each when you're talking 275/35/18s
Ok,
Can i get confirmation from these people that they still want the timers
(i don't want to be left out of pocket on this).
Aberax
Destroy
semislickR32
Tangles / writeoff (Share)
Scandyflick
BIT SUS
Krishy
4dr taxi man
HELSLO
Josh (What's his username)
Heslo
Heslo's +1
If people want to pay before hand them send me a PM and i'll send you my bank details.
Ok,
Aberax
Destroy
semislickR32
Scandyflick
BIT SUS
Krishy
4dr taxi man
HELSLO
Heslo
Heslo's +1
Yep, i am still up for this.
yes from me, although it isnt important for a good day out
dont you lose $ on it mate
+1
should i spend $1024 on 2x new toyo R888s
or spend $1100 on 4x Kumho KU36's ???
*watches weather forecast....*
I'll be running R888's cos i have no other tyres to use. Been heaps busy lately and haven't even started to get my car ready. Got to install front camber arms and get an alignment, fit new brake pads and install roll cage, mount rear wing, change oil and hopefully thats all. Also haven't received my CAMS licence yet that i paid for ages ago :)
Dale im still keen on the timing gear.
Edited by DSTROY
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
