$18,000 call or sms Jez 0414879711 located central coast NSW
this is a fully built car, nothing to spend just keep changing tyres :D
i sold my old GTR to build this car, i love this car but its time for me to get another GTR so its time to sell.
i built this car to handle drift and drag racing, i have only done a few track days since the big makeover and
been to the drags twice with a best of 11.32 1/4 mile @ 127.55MPH this is with drift suspension and fully setup for drift. big improvements can be easily made to get into the 10's.
car makes 272KW on 21PSI. with some e85 or race fuel more boost can be safely put through this motor.
with the tomei solid lifter conversion this motor safely revs to 8500rpm and can be revved to 9000rpm. for a SR 20 that is awesome.
see an interior view of this car in action
I will try my best to add everything but im sure i will leave a few things out and i will update it as i remember.
91 S13 Silvia.
ENGINE
SR20DET 2000cc
fully built by TM Autosports
JE/Nitto pistons and rods
ARP studs throughout
Nitto headgasket
ACL race bearings
GTiR oil pump and oil pump drive with modded oil pick up
solid lifter conversion with tomei parts,
tomei solid 260 12mm cams
Vision cam gears
extended sump with baffles.
BOLT ONS
Garret 3071r .8 rear housing mounted to a low mount GK tech stainless manifold modded to suit the Tial 38mm external wastegate thats on it.
JJR 3inch bellmouth front and dump pipe, JJR 3inch exhaust with crisp note.
2.5 inch custom intercooler piping to big front mount.
custom intake to turbo.
custom clutch
740cc injectors on stock rail. walbro intank fuel pump.
oil cooler relocation and cooler kit.
JJR radiator and nismo low temp thermostat.
custom oil catch can that never even sees any oil
DRIVELINE
custom clutch (will update brand once i ask my tuner)
kaaz 2 way LSD with rebuilt 4.3 ratio diff.
SUSPENSION
absolutely everything has adjustable arms front and back with pillowball joints
HSD HR coilovers.
whiteline front and rear upgraded swaybars.
front strut bar.
NP Wonder steering knuckles that gives ALOT more steering lock and reduced ackerman to give better control and speed while sideways
s15 front and rear lower control arms to give a wider track.
BRAKES
s15 front brakes (and rear brakes as spare)
R33 rear brakes with new rotors and project MU drift spec pads
Hydraulic handbrake (E-BRAKE) D2 with 5/8 master cylinder to increase brake force with less effort.
ELECTRICAL
ViPEC V44 engine management
ViPEC boost control
ViPEC launch control
ViPEC flat shift control
SABER series 2 -oil temp, oil pressure, water temp and boost gauges mounted on dash.
INTERIOR
Sparco drivers racing seat with custom rails.
Drivers harness
Pair of GTR r32 front seats will be supplied
interior in the back is FULLY stripped
still has door trims and stock dash.
EXTERIOR
custom paint job with flared gaurds.
17x10 D1R's all round with 2 spare,
a spare set of 17x9 drifteks
URAS GT Wing that is easily removed and refitted when needed.
Edited by DVS32R
https://www.sau.com.au/forums/topic/303768-driftdragstreet-s13-silvia/
  • 4 weeks later...
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
