hey people, no not another problem lol
going to be making an exhaust for the s1. looking through just jap and looking at the 3'' mild steel belmouth dump pipe and 3'' catco highflow cat,
has anyone put a justjap bellmouth dump pipe on there series one?? did it fit ok??
anyone using the 3'' catco hiflow cat also??
https://www.sau.com.au/forums/topic/303770-muffler-help/
yeah the jjr bellmouth front dump is a good mod and will fit your series one. I'd get the mild steel option as its easier to heat up and re-work if you really need to... Should fit fine but every so often people have trouble with them tapping the floor or gear box support. have fun fitting it Haha dump pipes are so annoying espesh 3inch as the bolts foul on the pipe when you try to do them up.
Got a three inches catch cat myself too....... Good mod again to help get it breathing.
You will notice the most improvements out of these mods with some sort of tunability like piggybacks or an aftermarket computer. But I suggest getting your breathing sorted first so you don't need to pay for double dyno time if that makes sense.
Hope this helps
Chris
https://www.sau.com.au/forums/topic/303770-muffler-help/#findComment-5033168
Me two!
Yes getting the bellmouth on can be a pain. In a couple of places I had to use allen head cap screws. :thumbsup:
Yeah I should have recommended this too, have a spare car handy so when u get the bolts off you can zipp to your closest hardware store and get some hex headed bolts to suit.... They are a pretty standard thread size cos I had a few lying around in the shed from some kind off bike repair
https://www.sau.com.au/forums/topic/303770-muffler-help/#findComment-5033795
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
