Hey guys,
Started to notice discomfort with my clutch tonight while I was driving.
I'm not sure if the clutch is about to go out or not, I've never had to get one changed so I'm not to sure what to look out for.
Anyway, here's what I noticed;
when I step on the pedal it seems to make like creaking noise ( like an old door hinge).
After a few shift changes ( eg; completing 1st to 3rd or 4th the pedal seems to be sorta stuck halfway when I depress and wouldt bounce back up and needs to be pulled up gently with my foot )
however, I do not notice any slipping or high RPM with low torque..
Anyway, clutch experts out there, please do help me and advise me that I need a new clutch or if something can be done to fix it..
Thanks in advance and hopefully I do hear some advise from u guys..
Calvz
The gearbox needs to come out to fix the creaking mist likely anyway. Have it removed and the problem will reveal itself. I'd say the pivot ball is dry and/or broken. Could be the diaphram in the clutch cover also.
thank you for the reply.
I have heard only good things about you n ur knowledge so I'll take that advise and check it out..
Shame that ERD isn't in Victoria, cuz I would prefer to get it checked out by u as I don't really trust other mechanics because they may exagerate the issue.
Cheers mate
Calvz
Crackling noise maby spigot bush is worn not sure see the reason I'm guessing is my mate had his clutch replaced (bakyard job) and the installer couldn't get the spigot bush out so they left it.. (i know..tools) but yeh the noise got worse work shop says "doesn't sound good at all ..." told him didnt replace the spigot and he goes thats prolly it...
now the peddle not coming back up ... put it this way.. u blow ur clutch the clutch peddle will stick right down lol so maby its on its way... now im not 1000% but yeah just from some small experience its all i can think of...
Is the creaking noise coming from inside the car ( Or seems like it is ?) As I had a similar experience with an R32..Turned out the pedal box broke a spot weld and eventually pedal fell to the floor...Lie on the floor with your head facing up under the dash and work the clutch pedal if you can , make sure you have a decent torch so you can see what is going on....If thats the problem its an easy fix-cheap too...I also had to put in a new clutch master cylinder as well...Whether or not this caused the initial problem I dont know, But it was cheap and easy to do as well
Edited by GTR-32U
Ohh and I forgot to ask the next part of the question, so is this real urgent? How much would it usually cost to get this fixed? Or do i need to get a new clutch asap?
Only asking cuz a bit short on cash this week and if I can put it off without having the clutch shitting itself within a week or two then it'd be great..
Cheers
Calvz
thank you for the thought and is much appreciated.. That could be the reason so will take that into consideration too
hey mate, cheers for reply..
Yes sound is coming (or seems like it is coming) from pedal area.. And it spuds like I am experiencing what u hae experienced in the past.. I hope that is the problem cuz like u said it's easy and cheap, and that's music to my ears! :banana: thank you.. And if ure still reading this thread, how long before te pedal fell onto the floor? And was it a DIY or time to visit the mechanics?
Cheers
Calvz
sounds like pedal box to me, have same creaking noise in my S13, ive replaced a clutch pedal box before in a r33 and took me 15-20 mins, 4 nuts/bolts you gotta undo in total, its a piece of cake, just hard to get to the very top bolt under the dash (2 nuts on your master cylinder you gotta undo, and 2 under you dash that hold the pedal box), with a few extensions on your ratchet you'll get the very top nut/bolt. Thought ill write it up just in case hahaha
Thanks for the reply.. Yerr I hope it is just that cuz that does sound easy enough to fix. Wandering why the pedal wouldn't bounce back up to it's full original position if it is pedal box problem, or maybe that is what's supposed to happen and maybe that how u can tell u need a new pedal.. Hmm anyway I gotta check that our today.. Thanks for ur help
Calvz
The problem can be any of the things mentioned above. There are so many components to the system that it is very hard to determine an exact cause.
Usually a cracked pedal box will cause a clicking sound rather than a creaking sound as the two broken metal pieces click past each other. The pedal getting stuck half way can be caused by a broken pedal box when they get really bad but usually you won't be able to pull it up again with your foot because the reason it is getting stuck there is because the pedal box is bent.
It could have a hydraulic problem and the hardness in the pedal can be due to one of the cylinders becoming stuck or blocked. Check the fluid level to see if you have lost any fluid. Check by removing the lid as sometimes the master cylinder can appear full because the fluid will leave a stain.
Get someone to press the clutch pedal in and out while you crouch in the passenger side to see if the noise is definitely coming from inside the car. Then jack up the car and listen underneath. You will soon identify the location. Once you know the location of the noise, you will have a better idea of where to start your repairs.
If the noise is 100% coming from the pedal area, then the clutch is most likely fine
If the noise is coming from the gearbox area, then it will have to come out. Before removing it, you could try greasing the slave cylinder push rod where it touches the throwout fork to see if that is the cause also.
You may have a combination of a few different problems, creaking push rod, leaking cylinder, cracked pedal box all at the same time, check everything over thoroughly before taking on a largish job like removal of gearbox.
Wow you are the man in the know! Really appreciate that reply.. Now I can do what u have mentioned above before I make a trip to the mechanics.. Thanks heaps dude.. Really appreciate it..
Cheers,
Calvz :thumbsup:
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
