spotted Gibbo_R35 at work today! I walked outside and he was parking, i would've stopped and said G'day but i had to get my morning coffee..then i'm pretty sure you walked into Savannah's...but didn't wanna say anything incase it wasn't you lol
lol, Yep it was me, having breakfast.
Say hello next time mate.
I didn't know if it was you and didn't wanna look like a knob saying "excuse me sir do you own the pretty white car outside?"
LOL
But yeah next time if i see your car i'll say G'day
While in Sydney and travelling back to Bathurst today spotted 2 R35s, more than any other GTRs... They are getting as bad as WRXs.... 1 White grey sitting at a Tyres and more unsure of Suburb, And then a White heading towards Sydney at Meadow Flat "SC" plates, flashed and waved, was in a silver R33 GTR
silver R35GTR came into Northside Nissan to get his key coded but unfortunately couldnt do it cuz he only had half a key. had a NISMO BODYKIT must be bloody expensive and had 22in Rims on it too.
  • 2 months later...
I wonder if the two guys taking pictures of my white R35 yesterday are going to post here.
First day out, first time parked, literally 3 hours after I picked up the car from the dealer I had photographers.
Very strange feeling watching from my spot at the cafe people poking and taking pictures.
saw a silver R35 GTR on millers rd.....
first time seeing it on the road....didn't all that much of the R35 didn't think it had that aura.. but was i wrong
after seeing this i understand why its so special, plus can't believe how complaint the car looks on the outside
not like my r32 gtr which bounces around.
  • 5 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
