doubt it, the high maintenance costs have been as over exaggerated on the interweb as 2012 end of the world conspiracies
im figuring gfc for the main part, end of lease for the 09s perhaps
Edited by domino_z
Saw a clean black 35 with custom plates on the cnr Shirley and Aiken rds, can't remember exactly what they were. I've seen the same car around before (got a wave). Looks the goods.
Edited by n11smo
thread bump
haven't seen an R35 on the road for months
seems they're all on carsales
I see a gunmetal GTR with H8 TAX plates on Preston Rd Manly in Bris on occasion. I live just up the road. Might drop in for a chat next time I see it :whistling:
Who spotted who? LOL
Mick pulled up behind my N1 (whilst I was munching on my Sausage and Egg McMuffin) and wondered what it was.
Nick fellah Mick...
^ ^ ^ Yes, they're both nice - both spotted!
Terry, I luv your n1...its a classic!
What would u expect to pay for an n1 these days in pristine condition like your example?
Nick fellah Mick...
Gunmetal (so I thought it was in the dark) R35 going eastbound on the M2 tonight (7-8pm). I thought the plate was "R35" but I might have just seen what I wanted to see???
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
