  • Replies 54
*sigh* here comes the publicity :thumbsup:
Hard to say what caused the accident though, out in Gidgegannup there are some fast roads, so he may not have been doing anything wrong. Will have to wait and see... In any case, hope he rests in piece.
https://www.sau.com.au/forums/topic/303832-such-a-waste/#findComment-5033802
car ripped in 2 means a good chance of doing something wrong but that doesnt take away from the fact that it is still sad. most of us including myself went through that stage, luckily most of us come out the other end - but i lost a mate on the way so news stories like this make me cringe
https://www.sau.com.au/forums/topic/303832-such-a-waste/#findComment-5033823
yeah i heard it on radio.. near toojay?
but least he is with his pride a joy o.o
"A Bellevue man died last night after the car he was driving split in two after slamming into a tree in Gidgegannup.
Insp. Trevor Davis said the 23-year-old lost control of the Nissan Skyline he was driving on Toodyay Road near Roland Road about 10pm .
He said that after rounding a bend, the car slid for more than 70 metres before hitting a tree on the driver's side.
"The impact was so severe that the vehicle split in two, the front end coming to rest 16 metres past the impact point," Insp. Davis said.
The man died at the scene. It is believed speed was a factor."
http://au.news.yahoo.com/thewest/a/-/break...split-in-crash/
https://www.sau.com.au/forums/topic/303832-such-a-waste/#findComment-5034030
Ouch....
https://www.sau.com.au/forums/topic/303832-such-a-waste/#findComment-5034059
He wasnt necessarily driving like a hoon, a few years ago i lost a friend to a similar accident, her car swerved and hit a tree but it caught alight, and im fairly certain she wasnt hooning.
It could happen to anybody.
Poor guy, RIP.
https://www.sau.com.au/forums/topic/303832-such-a-waste/#findComment-5034097
Poor dude.
What's even worse is that it was all the way out there.
Next car to drive past you if you crash could be half an hour away, then you've gotta wait for an ambo, and then survive the trip back to the hospital .... bad place to crash at high speed.
https://www.sau.com.au/forums/topic/303832-such-a-waste/#findComment-5034227
Pfft that's not remote.. when I was up north over Xmas I was worried about hitting a cow, rolling the truck and bleeding out in the middle of nowhere.. hell, on Xmas day we went 11hrs without seeing another vehicle on the road.
https://www.sau.com.au/forums/topic/303832-such-a-waste/#findComment-5034265
No shit, but Gidge isnt exactly a busy area either even at 7 in the morning.
Its fairly busy on weekdays on that road, everyone uses it, but sometimes it becomes fairly quiet,
anyone know who it was yet? :[
https://www.sau.com.au/forums/topic/303832-such-a-waste/#findComment-5034330
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
