hi guys i have a vl which is a pretty good car and i have always been a holden man but my mate took me for a spin in his silvia and wow its pretty good
so would a silvia be a good idea if i wanna do a bit of drifting in the back streets cos my vl cant drift i think its not that good maybe because its a v6 so pretty crap and silvias are turbo arent they
or maybe a skyline r32 would be good for drift to i asked this question on nissansilvia.com but noone was very helpful so i hope you guys can help thanks
https://www.sau.com.au/forums/topic/303839-looking-at-maybe-an-import/
Or just turbo your VL!
You're buying the car for the wrong reason.
People who have an attitude like yours are the reason hoon laws were brought in.
Take your attitude to the track and leave it there.
My opinion - Buy a Suzuki Mighty Boy.
im not sure if you are joking about the suzuki cos i dont think they would drift easy at all
and whats the problem if its in the back streets where people wont be around and it wont hurt anyone really plus the track is too expensive
um... lol? my first car was a VL and my next car was a n/a silvia. The silvia was such a better car there was no comparison whatsoever. both about the same speed...but ride/build quality didn't exist in the VL.
no you can get n/a silvias but in any case if I see you drifting in any streets near where I live you better hope the cops get to you first...
cant understand why that would be the case...
anyways, by all means buy a silvia or 180sx - both are great for drifting due to being fast and very light (especially the back end) but in any case - drifting doesn't belong on public roads. and if you drive like that then neither do you!
Edited by pixel8r
Successful Troll is Successful
Holden VL's are Straight 6 engines...
You sure you know what you got?
:thumbsup:
my vl will beat you fagna anytime its a shame its fwd because that instantly makes you gay where do you live i wouldnt mind doing a drag with you in a back street
fagna, thats a good one, mever heard that one before :(
if you were actually serious i would give you a go at calder, although thats probably too expensive for your full sick VL.
Some one needs to learn about car's.
The vl can drift there are two with top end drift associan that drift quite well
the eng in the vl is the same as the R31 skyline
Serosly a vl is worth only about 4k a r34 gtt is about 25k so you would pay him the cash and why would he wont a vl anyway they are plaged with problems v thr r34 (and even r31)
Think you should stick with your vl and be fully sick in that and let the cops catch you on the street's. at least it may take the heat of imports then
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
