Come on man... you HAVE to ask?
HOUSE PARTY!!!! and it'll go something like this (im trying to tell a smily story so forgive me if it dont make sense)
im gonna walk in and do the greetings :wassup:
then crack a beer :D
Then maybe a bit of a dance :rave:
Then i'll hopefully see a nice young lady :aroused: and one thing :cuddle: will lead :inlove: to another :boobs:
otherwise it'll be a long night :whackit: :)
and hopefully i that will make for a good night :)
We have a similar issue with different people wanting to do different things.
So currently we are thinking of a house party to start with and then going to twister! 5 different rooms with different types of music - $35 entry which comes with $25 drink card. + fireworks etc.
www.twister.net.au
There are always plenty of women of negotiable affection at twister too which is exactly what you need on NYE! :D
yeah but a few of our mates chicks dont drink. which mean multi drink cards and free lifts! :D
StKilda wont be that bad for taxi's either - not as bad as somewhere like Together. Its a closer stop than town for those cabs that have had to go down south for drop offs.
well, the last idea we had was renting a mini-bus, and driving around town... We got a mate who will screw almost anything when blind drunk, and a video camera. I was hopeing to find some toothless chick for him, and make my own version of the bang bus. Ten I'll have an applicable image to post......
Only thing is, our women may not be 100% on this idea..... dunno why :confused:
Heyyyy, I remember her.
Nice dig into the archives there mate.    Imagine all the fun you could have with a few hectares of boob when they're that big?
Haha - yeah I figured I'd go for some cruise-boobs :D
And, yes. It would be like your own private bouncy castle!
2-posts to go E
well we were gonna go into the city probably somewhere on brunswick st, and then after NYE countdown all my mates were gonna come back to my house n have a lil drinkup/houseparty.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
