Hi
Has anyone else experienced a CD ERROR FO on there 6 stacker Bose System ?
I have just purchased the car and when I switch to disc I get this error ?
Thanks
Hey mate, you may wanna read the FAQ section - read before posting. Written by Chris Rogers.
Your answer is there.
sorry to hear about your unit Cruzen..looks like you may have to fork out $$$ unplanned..i just hate when that happens.
https://www.sau.com.au/forums/topic/303872-cd-error-fo/#findComment-5034408
Hi
Thanks
BTW, End of day, you may need to repaired it or replace it. Member Si long Bao have a working BOSE unit for sale. I believe it will be easier for your to replace it.
https://www.sau.com.au/forums/topic/303872-cd-error-fo/#findComment-5035658
It happen to me as well.
Park car in the LUG for 2 weeks for oversea trip
then first day back to work put the car in the office car park with 40 + degree temp.
around 6PM, when i start the car and trun on music........... the bosh unit make some noise ..5 sec later "CD ERROR FO" showed on the screen :P:D
so i guess it could be the "heat" issue.....
https://www.sau.com.au/forums/topic/303872-cd-error-fo/#findComment-5038771
nope its age. the answer is in the FAQ I wrote.
F0 = guides,gears,loading trays - and that is only the start of it. best solution (though you lot bitch about spending $$) is to rip the lot out and go aftermarket. BOSE is NOT an issue. the 6CD mech is about $900 now and I'm still waiting on one ex japan for a customer (thats been 6 months!)
Now despite what you may think or have been told:
screen can be kept its NOT part of the radio
OEM panel CANNOT be reused unless you are doing a CAR PC or the like and are doing a lot of custom work. (you still need the A/C controller.)
Bose gear (amps and speakers) can be kept with a decent inteface (not the shit off ebay.) and it will work fine and have decent volume.
I do the panel sets for them and have part numbers for all colors of the dash. its as easy as asking me.
https://www.sau.com.au/forums/topic/303872-cd-error-fo/#findComment-5038915
yep! its on a separate server but I have done several with and with out bose. the only visual difference is your radio is in place of the orginal. send me an email and I'll flick a few shots your way.
https://www.sau.com.au/forums/topic/303872-cd-error-fo/#findComment-5039291
Email sent
Can't wait to see some of your great work.
Also is it a waste of time me getting the Jap to English software if I am ripping out the Bose Head Unit and replacing it with an aftermarket one ?
Or will I still retain the Fuel Consumption info etc. on the factory screen ?
I am assuming I will lose this info if I swap to an aftermarket head unit but Aus Nav & TV should be included in aftermarket unit hence no need to muck around with the Jap TV Tuner.
https://www.sau.com.au/forums/topic/303872-cd-error-fo/#findComment-5039482
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
