Item: Bolt-on Top Feed Fuel Rail for the R33 RB25DET GReddy Plenum
Features:
Bolt-on installation for the RB25DET GReddy Plenum
Maximizes any upgraded fuel delivery system
7/16" internal diameter insures fuel flow acceleration
Accepts most aftermarket 10.5-11mm injectors
Made from specially treated 6061 aluminium
Single entry single return configuration
INCLUDES ~ All necessary bolts, screws and brackets (NOW ALSO COMES IN BLUE)
The perfect bolt-on for our mirror polished plenum!
Only $145 including Delivery & Insurance !SAU MEMBER SPECIAL!
Condition: Brand New
Contact: 0401599023 (anytime) OR [email protected]
do you's make side feed for rb25's cause i want one like the top feed one ???
Sorry mate... we only stock these with a top feed injector setup
- Brendan
  • 4 weeks later...
  • 4 months later...
Finish of your new R33 plenum with this fuel rail set-up!
Bolt-on throttle bodies for the GReddy plenum also available
i have just thrown n brand new injectors that fit the rb25 fuel rail no probs. will this rail suit basically standard injectors?
and fit with the genuine greddy plenum?
PM sent mate :P
  • 4 weeks later...
Do you have rails that fit the 13/14mm aftermarket injectors, such as bosch and VDO??
Hi,
We only stock these for the smaller 10.5/11mm injectors such as the ones of the RB26 GTR.
- Brendan
hi mate i already have a top feed rail and injectors all i need is the 6 alloy things that the injectors sit in to seal to a gready manifold, can you supply me them? cheers.
jason.
jason.
Hi Jason,
Unfortunately, we can't supply parts of this set-up separately.
- Brendan
  • 1 year later...
  • 1 month later...
Hey mate,
A few guys on SAU have used these but I have no reviews I can forward onto you.
I've sold many of these and so far have not heard of any major issues with them.
Comes with fittings for top feed injectors and oil lines.
Cheers,
Brendan
  • 10 months later...
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
    • Righto,  enough of ADHD Anonymous! 🤣🤣 Rear end is completely stripped out apart from coil overs that will take 5 minutes.  Fingers crossed it doesn't look like that for too long!   Cleaning up some bits as I go so they can go straight back on. It amazes me how good stuff looks just with a good hard scrub! That will be it for a couple of weeks. I've got ot a bit of surgery Friday that will put me out of action for a few weeks. Hopefully the motivation is still there when I'm ready to get back into it!
    • The povo spec CA18S one, yeah. All turbos had 16x6.5 5 stud and 4pot brakes.
