Item: Bolt-on Top Feed Fuel Rail for the R33 RB25DET GReddy Plenum
Features:
Bolt-on installation for the RB25DET GReddy Plenum
Maximizes any upgraded fuel delivery system
7/16" internal diameter insures fuel flow acceleration
Accepts most aftermarket 10.5-11mm injectors
Made from specially treated 6061 aluminium
Single entry single return configuration
INCLUDES ~ All necessary bolts, screws and brackets (NOW ALSO COMES IN BLUE)
The perfect bolt-on for our mirror polished plenum!
Only $145 including Delivery & Insurance !SAU MEMBER SPECIAL!
Condition: Brand New
Contact: 0401599023 (anytime) OR [email protected]
do you's make side feed for rb25's cause i want one like the top feed one ???
Sorry mate... we only stock these with a top feed injector setup
- Brendan
  • 4 weeks later...
  • 4 months later...
Finish of your new R33 plenum with this fuel rail set-up!
Bolt-on throttle bodies for the GReddy plenum also available
i have just thrown n brand new injectors that fit the rb25 fuel rail no probs. will this rail suit basically standard injectors?
and fit with the genuine greddy plenum?
PM sent mate :P
  • 4 weeks later...
Do you have rails that fit the 13/14mm aftermarket injectors, such as bosch and VDO??
Hi,
We only stock these for the smaller 10.5/11mm injectors such as the ones of the RB26 GTR.
- Brendan
hi mate i already have a top feed rail and injectors all i need is the 6 alloy things that the injectors sit in to seal to a gready manifold, can you supply me them? cheers.
jason.
jason.
Hi Jason,
Unfortunately, we can't supply parts of this set-up separately.
- Brendan
  • 1 year later...
  • 1 month later...
Hey mate,
A few guys on SAU have used these but I have no reviews I can forward onto you.
I've sold many of these and so far have not heard of any major issues with them.
Comes with fittings for top feed injectors and oil lines.
Cheers,
Brendan
  • 10 months later...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
