well ive got 8kg fronts and 6kg rears with 32point damper adjust
and on the softest damper they are just a little stiffer than standard
brand is Largus its like an unknown jap brand but they are great i reckon, can still get them from import monster
turn up the damper and its really stiff
suspension can make or break cars handling. Id invest in a proper setup for your car so you get it right the first time and not end up pulling it out when the shocks bust or your car rattles apart from the stiffness.
I got Bilstein height adjustable shock absorbers with kingsprings progressive rate springs supplied by www.erd.com.au
Perfect for australian roads and tracks as they stiffen up as you push them (research progressive spring rates)
Any decent set of springs/shocks will set you back $1500 but its worth it as it will make the car more enjoyable to drive.
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
