  • Replies 73
AWEsome can i guess behavior is paramount since Grant Zippell has his name attached to this thing
and police presence may be there but not to defect obviously if you take a track car to the cruise have it adequately ticketed from the motor reg.
not to be a tard but who is grant zippel ???
Zippel Cruises are the biggest in Australia with much respect from the cops......in excess of 300 full US customs on most crusies.
Paying members only or by special invite on his regular cruises.
Someone enlighten me to whats going on? Has the land been purchased yet or we are still wasting our time on this? Pardon the blankness i been away for a while.
No idea bud, I'm pretty much in the same boat as you....passing this on for Grant.
Geoff Tartoosie of Extreme Horsepower is heading the Castle Plaza section of the cruise.
They're still fighting for the land to be available for purchase or lease from the Government. This has been pressured onto the Government for some time now, and a little birdie tells me its going to happen ... they're just stringing it out to look good in front of the press.
Come along and show your support. The Parliament House protest was a little low on numbers ... this one is a cruise, and we all know how much we like cruises! :(
what do ppl think the cops will be like?? i guess there gonna be there.. cant stop that...my cars not the crasiest but its kinda low nd loud but still tidy..
its not the time or place to be thrashing so i wont be doin ne of that just dont wanna get done for someting stupid....
what u ppl think
what u ppl think
Don't be a dick and you should be fine :P
I kinda tagged along on one of his cruise at the very back of the pack. So much respect for the cars. Some very awesome machinery and something u don't see everyday.
Cops shouldn't be a problem. The zipple and smasa cruises u could basically drive anything and be fine.
i'd love to come along and give some support and get my project out from under the blankets
i couldn't find it on the link but is anyone and anything invited providing they are on their best behaviour?
i saw the last cruise that went to ttp and i simply could not get over how many nice cars there were or the sheer number of cars, they were still arriving hours later!
i started honking a few as i drove the opposite way as i thought initially it was a small cruise, but they kept comin! eventually i gave up even waving because my arm was contantly out the window like a saluting member of hitlers young army
i'd love to show my support and possibly drum up a few fellow datsun enthusiasts but i dont want to be an unwelcome presence.
i'd also love to see the city jammed with modified cars - send a clear message for sure! basically be part of it
can anyone shed light on the "anyone welcome" before i start spreading the word?
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
