Hi all , someone I know has the 1.06 non gated turbine housing on a VL with an RB26 in it . He'd like to know what difference it would make having the mid sized or 0.82 A/R housing instead .
I believe ATM it makes full boost (~ 22) at a tad over 5000 revs and he would like that to ideally be 1000 lower .
Anyone been there with both these turbine housings on a GT3582R and an RB26 ?
Cheers A .
https://www.sau.com.au/forums/topic/303983-106-vs-082-gt35-on-rb26/
There is something wrong if he makes only 22psi at just over 5000rpm.
Noel's 33 (RB25DET) makes 26psi at 3800-4000 and 400rpm later on the 1.06.
Tuning, cam timing, the rest of the setup, will all determine how efficiently it will run.
I'm no turbo expert but why the hell ppl go for the largest turbine Garrett has to offer if they dont intend on using the turbo to its absolute limit?!?
The way i see it is that u choose the a/r of the turbine housing in relation to what average power u intend to make so say if the 1.06 puts the turbo in the 600hp range and u only want 550hp then go for the smaller back end with the advantage of improved response
Which brings me to a question....The hp rating garrett state on their site, is this when using the largest 1.06 housing?
So i guess it might be a question of if your mate wouldn't mind loosing some power if any at all to get improved response because i'm sure there will be noticeable difference between the 1.06 and the .82
You are almost right.
All of the GT3582's are rated to the same hp. The compressor determines air flow = determines hp output.
The turbine's are all the same size and the blade angles are all the same so there is no differences there.
The A/R of the turbine only changes shaft speed vs exhaust flow.
They rate their turbos based on the compressor maps which has nothing to do with turbine size. However, if you pick the smallest ratio, you will have a hard time getting it to flow the numbers later in the rev range because it moves out of its efficiency range.
eg. They will all flow exactly the same air from the compressor at a shaft speed of 120,000 rpm. The A/R or the turbine housing determines when the shaft speed will get to that point.
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
    • interesting....sounds like the later trans has software differences (or AM vs JDM). If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
