cheers for a little more advice i guess i will go to a performance place for some advice to answer some of your questions it dosent have a stock ECU unit its had a new monza fitted one... i duno how good that brand is... and yeh i do get a bit of backfire sometimes and the car has stalled occasionally when ive been driving it but not really often just rarely. the boost is run really really high... on my boost gauge it usually is at 15 sometimes.. 20... i duno this is all just figures to me.. i think the fuel lines have been pressured to release maximum? this is just a few things coming from my home mechanic. duno if its right?
15psi sometimes and sometimes goes all the way to 20psi on stock turbo?? Also your car stalls when driving?
What is controlling your boost? Your turbo wont last long if what your saying is true....
My god you have opened a can of worms lol Your better of going to a performance workshop and getting someone with exp to have a look at your car in person.
  • Replies 60
lol hanaldo i actually meant to say how much boost can it handle because i wana get an aftermarket fmic and afc..no worries johnnyboi and it sounds like u having boost spike from wat u were saying with da psi jumping from 15 - 20 so yea ken-r34 is rite especially if ur turbo is stock
No, the idea of a blow off valve is to keep the vacuum in one direction. Surge occurs when the throttle body closes and high pressure air has nowhere to go.
Even if the blow off valve is small, it still keeps vacuum in one direction, and then once the air passes through the blow off valve, it goes through the turbo (again) which is no longer compressing (or compressing as much), so the pressure is released very quickly on both sides of the turbo.
With FMIC, high boost and you've got a responsive intake system, if you drop from full boost/redlining down to idle quick enough, you will get some surge for a split second, depending on where the blow off valve is located (the further away from the throttle body, the more likely) and how long the blow off valve takes to open.
How can the charge - between the throttle body and compressor - that is sent (by the bypass valve) to between the compressor and AFM, all get sucked back through the compressor if the throttle body is shut?
I understand the bypass valve equalises pressure either side of the compressor, but I don't see how in a situation going from WOT (and full boost) to closed throttle and idle, you don't end up (after bypass valve actuation) with pressure either side of the compressor which is equal but greater than atmospheric, and so you get atmospheric venting back through the AFM and POD/Filter. The volume of air downstream of the compressor (thanks to FMIC etc) is just too much to be equalised back to atmospheric by venting into the upstream side of the compresser?
Sounds like your car is a time bomb. :)
At 7000rpm, you're filling up 2.0 or 2.5 litres of air 7000 times a minute...so air is getting sucked through fast. No matter how quickly the throttle body shuts (which is never very quickly with a single body) the amount of air remaining between the compressor and the outside of the throttle body isnt much ... only enough to full the pipes from the turbo to the throttle body...it gets recycled back through the compressor to lower pressure and slowly that remaining air is still sucked into the throttle body via the idle control.
So yeah, just because you're at high rpm and full boost, it doesnt mean there is any MORE air (volume) before the intake plenum, it just means its flowing through faster.
And for air to be sucked back out the AFM / POD, the vacuum would need to be going the other direction - the only way that is possible is in the event your turbo does scream like a Flippy when air returns to it.
Edited by Nic_A31
His point was that stock BOVs can handle any amount of power, since power does not affect BOV operation, and BOVs do not affect power/performance.
If you did for whatever reason need a bigger one, you'd receive it with your turbo.
stock bov leaks.... therefore it can not handle any amount of power
lol all gud..in Nz there were heaps of them they mean cars..oh well im off got this stuipid 3 day induction for tafe im the only apprentice technician all the others are in da building industry haha but its all gud
It really doesn't matter how much power you are making. The point of a BOV is to compliment the turbo, they release the pressure so that the air doesn't get forced back through the turbo, slowing the rotational velocity of the compressor wheel which means the turbo will take longer to spool up (and also potentially causing damage to the turbo). A BOV is just a valve, with the only purpose being to release charged air. There is no performance gain from an aftermarket BOV compared to the factory one.
The only reason to change the BOV would be if you were running very high boost and the valve wasn't letting all of the charged air escape
I don't think it's much of a case of letting all the charged air escape as that is airflow and comes down to the size of the turbo involved, not necessarily the boost level.
The problems with running high boost is the spring pressure may not hold the bov closed when climbing high into the boost, forcing the bov open and effectively having a closed loop boost leak.
Agreed, especially if it's run atmo.
Tony et al, I think something you guys are missing is that the stock bov is going to be held open ALL the time that the engine is in vacuum so any residual boost is going to be constantly recirculated while the throttle is closed till there is no positive pressure left.
P.S. I have just fitted twin GTR bov's to my 32 (along with full GTR piping/cooler/recirc pipe) so we'll see how they handle 25psi through a GT35R when the engine is finally put together :banana:
yea i think kaido is rite and think about it y would da japanese make atmo bov if they were useless? lol anyways do u guys go on much cruises? would be nice to meet fellow skyline owners
Probably the same reason they made those hektik sik turbo fans that you stick in your intake pipe and totally give you AWSUM POWA while improving fuel consumption. Or maybe they are from the same makers as those fake turbo whistlers, they are pretty useful when trying to prove to everyone how big your manhood is...
Lol, believe it or not, most stuff is made to make money. Lucky for them, there is always someone out there that believes what they are buying either works, or is the coolest invention on the planet. Nuff said.
You should check out the events section for cruises, although there isn't much going on right now :banana: Still waiting for the season to kick off again
okay... this is promising... ok so performance place what we talkin like...? the car probs is better i just duno what im talkin about.. haha id prefer like one of you blokes to have a look id feel that performance blokes wud be trying to say its stuffed just to make me pay em money and crap like dat unlike u blokes u dont need anything... i duno i guess ill go see one just give me a good place nd ill go.
No way man, you go to the right place and you won't have to worry about that. Check out the consolidated workshop thread, all the shops in that thread are highly recommended and very professional.
Autoworx is my recommendation, Alistar is a top bloke
ahh tru autoworx sounds good, their just round the corner from me! cheers hanaldo ill let you know how it go's and ill get back to you all about how fu#5ed up the car is haha
Correct :)
If anybody still doesnt understand BoVs, look at Wiki ... it has a colorful picture and shit.
You should check out the events section for cruises, although there isn't much going on right now :ermm: Still waiting for the season to kick off again
What season ??
Erm...can't say I agree here. The reason I give soo many 'Liner guys shit on WA is that 99/100 take them into workshops and get shafted. Just because they have a shop or "skills" it doesnt mean theyre honest or the most effective way.
Besides, look what can happen if you give your Lambo to a mechanic.
The problem in mention isnt complex, it wouldnt hurt to do this in his own driveway and learn some basic shit about his car.
Edited by Nic_A31
Correct :ermm:
I posted pretty pictures :)
What season ??
The cruising season. Duhhh :) Just means im waiting for some to get organised haha
Thats why there is the consolidated workshop thread, people have experience with these guys. There are actually mechanics out there that aren't just trying to make a quick buck. Some of them are interested in the car scene and a honest about their business. Its just about finding one you can trust.
I do agree 100% though, i would much rather do my own work to my car if i feel i am capable, but if he isn't confident of doing a good job then he would do better to take it to someone who knows what they are doing
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
