Hi,
My mate gave me his R33 front bar.
But theres a couple of problems with it
Firstly it has a crack in the bottom of it
and also i want to insert some mesh in the two bottom corners of the bar. But hes chopped away at it and both sides have uneven sides.
What do you guys recommened to repair a crack?? I want something i can apply which will fill in the holea and i can sand it back?
Also what do you think i should use in terms of lasting and durability for the mesh?
And what do you recommened to keep it held in place?
thankyou
https://www.sau.com.au/forums/topic/304013-front-bar/
that to me looks like a series 1 or 1.5 front bar.....best thing to do is contact a Japanese Import Wrecker and see if they have a front bar of same sort in stock in good condition....JIS have a shiatload of panels and kits.....that will be cheaper option for you mate.....
hope this helps :(
https://www.sau.com.au/forums/topic/304013-front-bar/#findComment-5036196
well
first
take it to a
panel
beater.
then he will fix it, rub it back, and fibreglass in some metal tabs that can fold down to support the mesh.
go to autobarn
buy mesh (not blue)
then the rest is up to you
good
luck
https://www.sau.com.au/forums/topic/304013-front-bar/#findComment-5036220
it holds a special place with me for the fond memories for the net sau vs ns.com battles that soon followed its arrival :D
Yes ... I had deeply apologised to NS.com for not fitting cheap chinese or ebay parts to my car ... warranting their slagging, so they attacked the blue mesh. Clearly my error was not consulting them on how I should have modified my car. Shame on me for doing what I wanted and looking up brand names like Nismo, HKS, Apexi, Sard, Gates, Walbro, Turbosmart, BBS, just to name a few. :P
https://www.sau.com.au/forums/topic/304013-front-bar/#findComment-5036686
LOL you really need to ask!?
Would look better with my boot sunk into it :O
And on a serious note, I fully understand ns.com's lifetime ban just because you have blue mesh. :)
Take ya tractor and your rig, and move along old man :) We're perfectly capable of going OT without your assistance! :O
https://www.sau.com.au/forums/topic/304013-front-bar/#findComment-5037176
don't listen to half the people on here man... no one does their own stuff these days. no point taking it to a pannel beater or buying another one as youre gonna get ripped off either way.
that's an easy fix and you can do it at home for next to nothing.
i bought same style bumper bar off a member on here which was completely ripped in the bottom section, had 3 cracks through it.
(sorry no pics of before)
tools i used,
soldering ion + zipties
bog
primer
paint
firstly, align the cracks to where they ripped. Get someone to hold it in place or simply use duct tape to hold it all together temporarily.
use the soldering ion to melt the cracks and use zipties as a plastic filler, work the plastic in to itself with the soldering ion untill its completely joined together, it should look something like this:
then grab bog, mix it and fill in the uneven surface till it covers everything, sand it and keep repeating till its the right shape...
primer n paint. presto.
i did it matte coz i was gonna respray the whole car like that at the time. unfortunately i smashed and cracked the bar again a few times so ill be doing this myself again soon.
hope this helped :P
Edited by SkyHi_33
https://www.sau.com.au/forums/topic/304013-front-bar/#findComment-5038503
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
