LOL!
Paul, if you were in Sydney you could pump your sound system up and drive REAL slow up and down George St. That's what all the cool kids are doing these days.
Also, PJ, I love your signature. 'My other ride is your mum' had me in stitches
Wow so many Haters
Well it looks F#*king Awesome
Still not feeling it.
But I do respect the fact that you can't be eff'd about what others think and mod your car the way you like it. Look forward to seeing your car in person if your coming for the cruise.
if you dont mind my personal opinion....u need to work on the lights coz the yellow headlights dont match the rest of the other bulbs and you could use a lowering an inch or 2. :)
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
