Rb20 ECU $120
Nistune chip with transplanted rb25det maps around $220 i think.
Few $100 for quick tidy up fine tuning
double that.
http://www.nistune.com/boards.htm
DRDRIFT is good at his job and that price is very fair, i wont do it for less than 1k
Im getting the z32 ecu with nistune installed and tuned for $900. I think the only advantage of the z32 is that it retains the vct. I would say 700-800 is a pretty good price. Make sure to shop around though because i got quoted $2000 at one place i rang, i choked on the phone when he said that.
haha @ 2k that buys alot of stand alone ecu's, i feel bad charging 1k, but it aint worth my time touching it for any less.
double that.
420 if you want the software so 220 is correct for just the chip i know because it's the price i paid i also installed the chip myself
Edited by Crans
still double as no-ones gonna bother tuning it for a couple of hundred, was my point.
or you could just buy an off the shelf powerfc for $1k and use that?
when your finished, sell it for the $1k you brought it for, no money lost
still gonna cost you another 500 (so 1500) to get tuned at most decent shops... i prefer the PFC in 33's to though.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
