So my cars going in on wednesday to get a z32 ecu and nistune installed and tuned up. Im very excited to say the least. Anyway the car has the basic mods, full exhaust, fmic, pod filter, manual boost controller and its getting a new fuel pump on Wednesday as well, just as insurance against fuel supply problems.
So basically I was wondering about the rev limiter on rb25's, how high can you go on an unopened engine. I know this is a "how long is a piece of string" question. So i was hoping that people could speak from personal experience, i.e how high is your limiters set?
From what ive seen 7,500 seems to be the limit, but im not really sure.
Also with the fuel pump the one to get is the Bosch isn't it? The mechanic said to get that or the walbro, and i said i wasnt sure, ille leave it to him. And just now i read about the walbros being crap and having random failures so i might ring him back and tell him i want the bosch. Sound good?
https://www.sau.com.au/forums/topic/304063-rb-25det-rev-limiter/
I know the factory limiter is around 7,200rpm i think you will find power will likely drop after this anyways. But is there really a reason to rev it that high in the first place?
My 33 with front mount, cat back, pod, 10psi best shift point is bout 6k.
And yes bosch pump is the way to go
Yeah I agree with your point on power dropping a bit at the high rpms, probably because the stock turbo is running out of puff. As for reasons to rev that high, well basically the higher you rev, when you go into the next gear you are going to be higher in the rev range. And as for you changing gear at 6000rpm, thats not a problem, but dont you notice that power keeps increasing all the way untill red line? I certainly do and therefore ussually change gear at about 6,900. That is if im giving it the boot.
well u have more mods than me so thats possible as no i do not feel the power keep increasing.
also it will shorten your engine life. So i would suggest maybe open her up and build an engine for reving out if thats what you want.
Factory rev limit is 6900.
7k. any higher with a stock turbo is pretty pointless
Give this man a medal - post of the thread.
No point taking it any further than 7,000rpm, factory turbo is begging for a gear change by 7k, so why stress for no reason?
Keeping it at 7000 will preserve the motor much better.
On mine it is set to 7100 because my HKS2850 turbo drops off around there.
I have done 120,000 kms on a stock motor pushing 320+ HP, drags, track and it still runs sweet, I do have all the support mods needed.
mines on 7900 mate, all those under are just wimps ( yeh im prepared to get flammed it is SAU ) My 20 is even higher =)
whilst sliding wether power drops off or not you need revs, and like you said higher rev so next gear is up in sweet spot whilst changin.
i have power fc and can change this myself when ever i want, so speakin from experience 7 does not cut it.
Better to have it higher rather than too low and not be happy and pay again to get it changed with nisstune !
Edited by bbe
Why did this just give me a mental image of Einstein licking a window?
i dont really agree, if you are running a stock turbo.... i had 7100 dialed in on mine and it was definately outside the powerband... for drift i do understand that you need higher revs tho...
currently i have 7400 dialed in with the 2835, and i could go higher, but want to preserve the motor
didnt that guy with 485ish rwhp out of his stock internaled 25 (cant find thread) usually rev it to 7500 but when he raised the limit to 85 to avoid changing into 5th just before the line it threw a rod at about 8300 ??
someone else will remember the thread .
8500 that would just be awesome, goodbye ceramic wheels thou lol
At 7900 it still does sound smooth =)
I dont get the Einstein licking a window lol
Oh and their is nothing wrong with Walbro.
Edited by bbe
Ive got similar mods,
JJR coilpacks
3" turbo back exhaust
FMIC
Pod filter
Bosch 040
nismo Fuel pressure reg
Hi-flowed turbo
Z32 with nistune
mine is set at 7600 as thats when the power peaked. although i have my shift light set at 6800, by the time i react it get pretty close to the limit.
and u will be very happy with the nistune, i know i am.
so will the rb25 head macthed with a bigger turbo able to flow good enough to still make power around 7400-7900??? i have heard good things about the rb20 making its way up to 8 or so but the 25???
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
