So my cars going in on wednesday to get a z32 ecu and nistune installed and tuned up. Im very excited to say the least. Anyway the car has the basic mods, full exhaust, fmic, pod filter, manual boost controller and its getting a new fuel pump on Wednesday as well, just as insurance against fuel supply problems.
So basically I was wondering about the rev limiter on rb25's, how high can you go on an unopened engine. I know this is a "how long is a piece of string" question. So i was hoping that people could speak from personal experience, i.e how high is your limiters set?
From what ive seen 7,500 seems to be the limit, but im not really sure.
Also with the fuel pump the one to get is the Bosch isn't it? The mechanic said to get that or the walbro, and i said i wasnt sure, ille leave it to him. And just now i read about the walbros being crap and having random failures so i might ring him back and tell him i want the bosch. Sound good?
https://www.sau.com.au/forums/topic/304063-rb-25det-rev-limiter/
I know the factory limiter is around 7,200rpm i think you will find power will likely drop after this anyways. But is there really a reason to rev it that high in the first place?
My 33 with front mount, cat back, pod, 10psi best shift point is bout 6k.
And yes bosch pump is the way to go
Yeah I agree with your point on power dropping a bit at the high rpms, probably because the stock turbo is running out of puff. As for reasons to rev that high, well basically the higher you rev, when you go into the next gear you are going to be higher in the rev range. And as for you changing gear at 6000rpm, thats not a problem, but dont you notice that power keeps increasing all the way untill red line? I certainly do and therefore ussually change gear at about 6,900. That is if im giving it the boot.
well u have more mods than me so thats possible as no i do not feel the power keep increasing.
also it will shorten your engine life. So i would suggest maybe open her up and build an engine for reving out if thats what you want.
Factory rev limit is 6900.
7k. any higher with a stock turbo is pretty pointless
Give this man a medal - post of the thread.
No point taking it any further than 7,000rpm, factory turbo is begging for a gear change by 7k, so why stress for no reason?
Keeping it at 7000 will preserve the motor much better.
On mine it is set to 7100 because my HKS2850 turbo drops off around there.
I have done 120,000 kms on a stock motor pushing 320+ HP, drags, track and it still runs sweet, I do have all the support mods needed.
mines on 7900 mate, all those under are just wimps ( yeh im prepared to get flammed it is SAU ) My 20 is even higher =)
whilst sliding wether power drops off or not you need revs, and like you said higher rev so next gear is up in sweet spot whilst changin.
i have power fc and can change this myself when ever i want, so speakin from experience 7 does not cut it.
Better to have it higher rather than too low and not be happy and pay again to get it changed with nisstune !
Edited by bbe
Why did this just give me a mental image of Einstein licking a window?
i dont really agree, if you are running a stock turbo.... i had 7100 dialed in on mine and it was definately outside the powerband... for drift i do understand that you need higher revs tho...
currently i have 7400 dialed in with the 2835, and i could go higher, but want to preserve the motor
didnt that guy with 485ish rwhp out of his stock internaled 25 (cant find thread) usually rev it to 7500 but when he raised the limit to 85 to avoid changing into 5th just before the line it threw a rod at about 8300 ??
someone else will remember the thread .
8500 that would just be awesome, goodbye ceramic wheels thou lol
At 7900 it still does sound smooth =)
I dont get the Einstein licking a window lol
Oh and their is nothing wrong with Walbro.
Edited by bbe
Ive got similar mods,
JJR coilpacks
3" turbo back exhaust
FMIC
Pod filter
Bosch 040
nismo Fuel pressure reg
Hi-flowed turbo
Z32 with nistune
mine is set at 7600 as thats when the power peaked. although i have my shift light set at 6800, by the time i react it get pretty close to the limit.
and u will be very happy with the nistune, i know i am.
so will the rb25 head macthed with a bigger turbo able to flow good enough to still make power around 7400-7900??? i have heard good things about the rb20 making its way up to 8 or so but the 25???
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
