Hey guys ive had my 33 for bout 3 years now and finally decided to query on this. On my center console next to the cup holder i have a switch wich says "light reduce". I have tried using it and nothing happens so no idea what it is linked to.
I do know there are wires running from it but to what i have no idea. Has anybody else got one of these? were they a factory option?
Car is a 97 series 2 GTST.
cheers guys
Edited by chubs
https://www.sau.com.au/forums/topic/304064-33-gtst-light-reduce-switch/
That switch you are talking about automatically turns off your headlights when you come to a stop. Apparently it is a courtesy thing in Japan for drivers to switch off their headlights when they come to a stop in traffic. May be fact or rumour but that is what I heard at least.
I have a '97 R33 S2 and also have that switch near the cup holder and it does exactly that; when I have my headlights on and have the light reduce switch on it automatically turns my headlights off when I come to a stop.
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
