u r chasing something similar to mine?
http://i286.photobucket.com/albums/ll87/si...o/aDSC_1401.jpg
http://i286.photobucket.com/albums/ll87/si...o/bDSC_1413.jpg
http://i286.photobucket.com/albums/ll87/si...o/bDSC_1415.jpg
http://i286.photobucket.com/albums/ll87/si...o/bDSC_1422.jpg
If so, and if you got the $$$ and time, try asking your local car importer as I am sure they can source your the full 2nd hand OEM set from Japan ex-wreckers. As to bodykits for sedans in Australia; they r as rare as hen's teeth (I, at one stage, wanted to dress up my car but decided that the factory nismo kit was good enough)...
If so, and if you got the $$ and time, try asking your local car importer as I am sure they can source your the full 2nd hand OEM set from Japan ex-wreckers. As to bodykits for sedans in Australia; they r as rare as hen's teeth (I, at one stage, wanted to dress up my car but decided that the factory nismo kit was good enough)...
Yep exactly like yours.. you sure you dont want to send it too nz:)
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
