that seems a bit high for stock turbos!
u should have used ben at race paces dyno it gives much more realistic dyno readings
No probs,
maybe when ICE install & setup my EVC, they can pop it down to bens. It would be a good comparison ;) to see varying result on different dynos
Hey guys, my car has HKS front pipe, super hi flow cat (hehehe), Apexi dual N1 cat back, adj cam gears, 1.1 bar boost (bleed valve) and Apexi filters....
Dynoed at BMT Motorsport with a supposedly low reading dyno last saturday and got 235rwkws.... with some awesome flamage.... not bad considering stock turbos and ecu......
Meshmesh, I was at Subaru on Monday - I spotted a lonely white GTR in the STI showroom - was that yours?!? and what the hell was it doing in the STI showroom and getting dynoed there? Do they actually do other cars as well, or were you calling in a favour?
Yeh Ronin, that was mine :cheers: . But what !! It was in the Showroom, Upstairs??
Dyno & tuning no probs, I don't think they'll do the mods for any joe blow. Vin is a "comparo of comparo" yeh wog talk :D "friend of friend" who managers Sti.
It was funny, I don't think Sti & WRX owners really get see above 200kw @wheels, when Vin had it on the dyno downstairs, there must have been at least 7-8 guys & subaru staff freakin out as the chart went off the screen @265kw. One guy rang his mate & had him on speaker, his mate was freakin out. I guess numbers like that really aren't that exciting to GTR owners, was just nice to rub it up Subaru :)
After that, some of our friends who own Sti's were upstairs, spewing coz most they got was 185~. They begged Vin for some power up advice to keep up with the GTR, which he replied with a big laugh. Looks like me & Vin convinced them to sell their cars & buy GTR's.
By the way what were you doing there...?? Do drive a Subaru & not tellind us about it?
We got 297kw at the rear wheels at BMT and i think it was 276kw at all 4 at some other place, hypertech...
Mods: Garret Turbos, exhaust, apexi powerfc, apexi pods, blitz intercooler., thats about it i think, dont know the exact parts and stuff like that...but im sure that they are all the mods...
Meshmesh, don't worry, it was in the worshop - but spotting a GTR is second nature to me :D
A mate from work has a WRX, he was looking at changing his wing to a STI wing - we were on lunch break. I wouldn't buy a WRX, unless it was a second car :)
Nice work with your results!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
