  • Replies 57
doxximus - id go PS2 just cos the controller setup is way better...i havent played either...but yeah...your choice
All - whats your faverite drift track...i know alot of people like track 2 but i think thats a boring track...i like track 4 myself....just wondering what everyone else thinks
i got onto that www thingy and ordered a psx converter from www.liksang.com
it is the BOOM ps joy usb directx force feedback joypad converter..
it cost a little under $30 aus delivered to your door or po box .
i have no problems with it at all . no delivery probs. comes well packaged and secure.
L8R
im stuck on race like 105/111 i think it is
its the one with 7 Laps
i cant farking beat it
the rest of the game has been fine, it just really doesnt want me to win this race
i can lead for 5-6 laps, then outta nowhere the s2000 in the race somehow flies past me ?
hehe....the imfamous enduro. Your not alone, I had probs wid that race as well :headspin: . My solution i that u just keep on racin n memorise the track, knowin when traffic try to smash into u n such.....worked for me. Or u can try wat a lot of other ppl say to do n downgrade yr car except for handling. Get rid of all yr turbos should make the computer players go slower as well....i havent tried it but it could work.
  • 3 weeks later...
If you're got a bit of electronics nous, the schematics are available on the web to make the PSX controller adaptor for PCs. The drivers are downloadable for free too (but you'll have to find the one that works best for you - there are heaps!)
No components in the schematic (unless you want the force feedback to work), just linking the different PSX pins to the pins on your parallel port.
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
