Hey guys n gals
any help on this would be very much appreciated :(
car is a 1996 s2 R33 gtst... its got a haltech E11V2, full exhaust, upg turbo, pod, cai, fmic, bov, 700cc injectors (i think), boost controller etc etc etc
it all started when it was runnin very rich, i mean u could light the oil on fire it was that rich lol... so i was like ok ill take it for a tune
tune went good started out at 143 rwkw! n went to 330 rwkw :) as well as fixing a few other probs... 2 days later car starts missing under all loads again! only thing i could see wrong was a few wires left near the turbo / exhaust were melted (O2 sensor, boost solenoid, air flow sensor) as the exhaust was runnin much hotter... i thought maybe it retarded the tune as its a haltech lol n took it back for a re-tune, n to move those wires
got the car back, all was well, 2 days later plugs are crapped again!!!!!! :) ... only thing i can think of is the injectors are rooted??? plugs in it were NGK BKR6E gapped .8mm... i was thinking going heat range 5??? burn abit of that crap off them???
https://www.sau.com.au/forums/topic/304133-what-to-do/
Dont use heat range 5 if your making 330 rwkw, that plug will run far too hot. You want at least heat range 6 or maybe 7 depending on how you drive.
Also have you upgraded your coils? or are you using the factory ones?
What do the plugs look like i.e. black, white, oily etc
Cheers
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5037725
Cheers
i actually just read that off the NGK website lol... might just stick with 6 then lol :)
coils are still stockies, thing is it runs fine for a few days then craps up again so didnt think it would be those
plugs are sooty n black
thanks man!
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5037730
Hey mate,
ive had very similar missfire issues to you, using the same plug and yeh... 1-2 days and they get shitty..
I now use NGK BCPR6ES.. honestly... never looked back, car is perfect up until about 10,000kms and then replace when I notice a little bit of spluttering, but its still no where near as bad as those BKR6E's....
Also, u know, normal things... check all coil packs for cracks, make sure u have the right tension for the plugs etc etc...
hope this helps.
Adam
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5037766
Hey mate,
hope this helps.
Adam
plugs FOR SURE
heat range 7 no less mate, easy sorted and a gun of a car by the sounds of it :(
haha i put the NGK BCPR6E 1ns in on saturday, has been runnin really well, cept still rich! gahh... i noticed the coppers were a lil bit longer where it goes into the coil than the iridiums 2 :laugh: wether that has anything 2 do with it lol
gunna get a flow test done on the injectors today, see if that is the damm problem
thanks heaps guys!
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5040125
found out what was wrong with the car lol
well the injectors were all pulled out n they turned out 2 be BA ford falcon injectors :D lol wtf
the sandwhich plate had been modified to fit these stupid top mount injectors into the side of the rb25, the wiring harness wasnt soldered anywhere n the wires just fell outta the injectors when they were pulled out lol... not to mention the injectors were full of sh1t
so gunna get the wiring harness all re-done, a nissan fuel rail with sard injectors n have to replace the sandwhich plate or whateva grrr
when the last owner finished all this genius work they forgot to tighten the bottom intake bolts! so they were all loose to! lol
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5053705
Hate to say it. But that has to make you feel confident about the car holding together with that power. Theres enough direct fit kits out there now not to have to adapt up something that doesnt belong.
If I were you I'd be looking over everything that you know is modified to double check everythings done up correctly/ no leaks etc. Just in case. The Joys of buying a premodified car. You may say money on the mods. But you also have to put up with anything they did that wasn't right.
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5053959
pretty much everything but the ignition looks good n car runs perfect when ignition aint playing up even had it smoke tested for leaks lol... just dun jynx me now lol :D
umm not quiet sure on the turbo as its got no brands etc on it... it has all the serial numbers on it but i dunno them off by heart lol
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5054089
What base pressure are you running? I ask because BA Ford 6 (incl' XR6T) injectors are only 295cc and for you to be making 330rwkw on 6x296cc injectors would make for an interesting duty cycle figure.
Also BA 6 cyl'r injectors are 14mm injectors so make sure that you order the correct SARDs as most of them are 11mm. I would look as running the same style as the BA 6cyl'r injectors but just larger and from someone like Bosch, from what i have been reading about the new style injectors there are some very good ones out there especially in high impedance.
Have a look here at the 610cc Siemens Deka ones;
http://www.injectorsonline.com/indivprod.p...=74&scid=11
Edited by D_Stirls
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5054493
yeh defo will aye, im actually kinda worried it is a cheap chinese 1 lol cuz theres no visible brands or nuffin
do u mean as in turbo psi???... cuz i run it on stock lol so 7 or 8... only rarely go 14, baby the damm thing lol
apparently the ford injectors in it were 650 - 700cc :D n the person actually drilled out the sandwhich plate 2 fit them in cuz they were 2 wide
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5054502
He means fuel rail pressure.
If they were 650 - 700cc I'd be expecting near stock fuel rail pressure
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5054612
hey guys... got the car all fixed up... well to an extent lol
put sum blitz 850cc injectors in with a nissan standard fuel rail, also had all the wiring harness fixed up from the previous injectors
the ecu also had a short circuit n some corruption, which was fixed up by haltec
after all this it was tuned n all went well
however now its bout 5 days after gettin it back n i think the car has fouled the plugs that i put in 3 days ago!!! :) gahhhhh
could it possibly be wrong gapping / heatrange of plugs??? or coil packs screwing it up??? as its the only thing other than ecu i can think of :(
https://www.sau.com.au/forums/topic/304133-what-to-do/#findComment-5077739
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
