Thought I'd post a couple of pics. My car has now had all visible rust removed with lots of new steel put in it's place. These pics are at guide coat stage, and it is smoooooth. Near all imperfections gone. New steel welded in around the boot, that strip that holds the boot rubber in place.Should be finished in two weeks. New colour: Bondi Bleach. New number plates: BLEACHED AS
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/
The job so far. Also all other bits like flared guards, light surrounds and garnish are gloss black. Pick it up on Tuesday and should be assembled by Thursday. Then it's off to Bali, me that is for 6 nights.
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5052452
i dunno man i
d [refer to see you do an engine swap with an RB rather than a v8. but you know that's just my taste. i have an RB20 in my silvia (around the same weight) and i tell you... it goes hard as hell!!!
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5053979
Hi Drew, yeah I still want to swap something into it. I just know the L28 isn't going to give me the HP I want. It has to be boost or V8. V8 seems the easiest as there's no injection to set up and I have the go ahead from the Dep of Planning and Infrastructure here in W.A. I love V8s' and love me coupe, so? That 210 at Jollys' has the RB30 in it, now if I could get the relevant bits and pieces, mounts, gbox crossmember, I'm assuming it's had a RB box in it and that's why it's gone. Plus any special looms that have been made up, this could alter my thinking. I just want easy or easiest.
ANYBODY WANT TO TAKE A LOOK AT IT FOR ME? I pay by the hour. Message me if doable please.
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5054647
Geez Ricky
I don't think a V8 would be a good idea mate.(IMHO)
L28 with tripple webbers would sound so cool with plenty of HP and be in keeping with the rest of the package.
Failing that stick with an RB20 or 25.
Looks great so far :D
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5054841
Andrew, I actually have a friend who is trying to sell me a L28 turbo set up.54/P90 Microtech computer, sequential injection, brand new ball bearing turbo( large), motor is fully rebuilt, and comes with plumbing but to suit a Z. It's 8.5 compression and running low boost. Has already had 240hp@TW and is apparently good for up to 280 + some. Problem is the price, he wants my motor and another 8 grand, this is the installed price but it's just a bit exy. Would be nice to stick with a high HP old school motor.
Todat I'm going to compression test that 308, he wants $800 for it.
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5055780
post-44326-1264678243_thumb.jpgpost-44326-1264678628_thumb.jpgpost-19495-1125201912.jpgStill needs a buff and the new rear flared guard put on. But the paint certainly improves it. I'll get the front springs cut to lower it a bit more soon. Oh and of course put the bumper back on. It's not a show car paint job, once buffed it'll look heaps better as it has a few blemishes here and there but it was noly $2500 and a lot of new steel went in to replace the rust and my patch ups. Overall I'm pretty happy with the outcome and it is the first car my mates painted in about 8 years.
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5059034
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
