1 hour ago, Dose Pipe Sutututu said:
BMW M4, a flash and an exhaust system and it will do low 11 or flat 11s.
Around most tracks it will leave most mildly modded GT-Rs at the starting line.
 Buy one
  • Like 1
  • Haha 1
R32 impressing old guys
R33 impressing wierdos
R34 impressing the ladys
Think I got it right. Can close thread now.
Can confirm 33s are weirdos. [emoji848][emoji50]
3 hours ago, r32-25t said:
 Buy one
Nah bought a Tiguan and the rest is going towards our European holiday soon, not to mention we got tickets to Tomorrowland :)
  • Like 2
On ‎4‎/‎18‎/‎2019 at 11:47 AM, Steve85 said:
I like this train of thought... here's mine:
R32 GTR - Dedicated Drag Car
R33 GTR - ~550whp Street Car
R34 GTR - Dedicated circuit racing car
I'm similar to this in a way. I just think: R32 GTR - go to town.
Big hp street/drag/circuit car.
R33 Gtr - modified stock engine if possible. Everything without changing engine ie. Stock bottom end if possible and low mounts. High mount means completely modified.
R34 Gtr - completely stock, maybe wheels, exhaust and filters - that's it.
Have the first two boxes checked. 89 GTR 92000km (bought at 80000km in 2008) and 95 GTR 82500km (bought at 67000km in 2004). Spewing not getting an R34 when they were circa $40k, thought that they were too similar to R33 mechanically (apart from getrag box and not ceramic turbines, what's the big deal with 34s ?)
Anyone wanna sell me an R34 for $50k - $60k so I can complete my trio ? Sold my last 91 R32 gtr for $17k (around 140000km in 2007) , fffffffck it. Might see it if I can get it back as I know it's sitting in a paddock wasting away.
  • Like 1
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
