Just wondering if anyone has managed to get a caged, tarmac rally or circuit / drift R32 GTS-t under 1200kg, or whether it's even possible? It would have to have all panels in place (ie no drift specials with bumpers missing etc) and 2 seats, complete dash still fitted. Not talking about exotic Cr Mo cages either but something fairly substantial.
Also not allowed to use titanium and carbon components - all panels must remain steel where fitted, and carbon not allowed
Would this be possible without costing $1M, or just a pipe dream?
  • Replies 72
Posted Images
I think for a track car it would be relatively easy. You can pull out a lot of bolt on bracing and stuff you wouldn't need, trim bumper reo bars, pull out lots of shields and covers and trim, wiring, electronics, sound, interior lighting, climate control...
As an example Group A HR31 Skylines were 1115-1180kg, and off the showroom floor a HR31 GTS-X is 1450kg.
I reckon 1320 -> sub 1200 is well doable.
no.
What's your explanation?
I think it's possible? Without rear seats, sound deadening, maybe put on a GTR bonnet as they're aluminium, as suggested maybe give the reo bars a trim and remove the hicas, audio and a/c.
Edited by -Jimmy-
even removing all of that you would be lucky to offset the weight of the cage, as a decent cage will weight more that 60kg
picked up a bhp-steel roll cage today, $5 purchase off ebay to suit a prado
it will be going into (modified) my r32 gts-t sedan track car; featuring rb26dett
guessing ~1400kg including cage less stuff taken out (seats, sound deadener, etc) perhaps 100kg
it'd be close to get down to 1200
lighter aluminium bonnet would help
take out the fuel tank and use a cell instead, perhaps?
smaller radiator overflow bottle, etc, trim back unwanted metal, etc....
Thanks for the feedback. I can't afford to sacrifice the strength of too many components, and cooling system will defenitely need to be up to scratch. I have generally found that a caged, prepped car weighs close to the factory weight of the standard vehicle (by the time you add in other stuff that I'll be needing)
Not sure whether regs will let me run the GTR bonnet yet.
I'm going of Benny Woosters numbers, he got his down to 1280 kg, with gtr kit, and pretty resnobale amount of weight savings, but his cage isn't hugly extensive. Short of carbon, titanium, and cro-mo cage, it won't be any lighter.
you can't look at a group a car for weight numbers. Fristly they had a pretty basic cage compard to todays standards, and things like most of the suspention being custom milled from alloy, and use of lightweight materails everywhere.
if you want to race for long stages/runs you have to add weight in to make it reliable, bigger radiator, oil cooler, bigger brakes.
Thats the truest words ive ever heard lol.
My 33 gtst will be heavier in "race use only" form than it was as a streeter.
By the time you add things like brake ducts (or air deflectors in my case) oil coolers, big radiator, cage, dataloggers, yadda yadda yadda. its quiet easy to go heavier...i mean a back seat weighs all of 7-8kgs, body deadener and everything else in the cabin is ~40kgs
also while im thinking of this subject...if you cut out the body bracing you will have to re-stiffen the chassis with the cage and by the sounds of what your limiting yourself to having all steel panels you want to run in a production catagory..and most of them do not allow through firewall bracing in the front or rear of the car, so the body will flop around like a wet sock.
That's exactly the sort of info I was after - thanks Sav Man.
Yup - long stages, high power, low speed, harsh roads - it will be copping a pounding unlike any R32 has probably experienced before
Won't be needing big brakes (in fact, I don't think I can fit anything bigger than standard under the wheels anyway). We are allowed to run the cage into the boot and engine bay, so no problems there. Definitely don't like the throught of removing stiffening braces, but will look at all parts and determine what is load bearing and what isn't (not too difficult if you have some idea of engineering principles)
Our weight limits are based on engine capacity. Stock RB20DET means I can go as light as 1180kg according to the regs, but that doesn't sound very achievable within our regs. The next category takes you up to 1260kg, which sounds about right. If I can't get the car below 1260 then I can look at boring / stroking to 2.2L if that will gain me any significant benefits (chasing fat torque curve, not useless dyno queen).
All just part of my research at this stage before I embark on the project. HAve some serious red tape to cut through first, so might not even get off the ground until that can be sorted.
Thanks for the help again.
To add to sav mans info. ive stripped down a few r32s now and the biggest weight areas are in the suspension. sub frame, cross member and associated bits. the actual shell weighs f all and thats why they require bracing ect ect. things like if the roll cage isnt tagged to the front a pillars then you will crack windscreens because of the twisting of the chassis. then the next biggest weight is the engine its self. its a heavy engine full stop and theres not much you can do about that.
body panels do save weight but its all marginal compared to the suspension components. ive tried to cut bits out of the doors and boot lid and bits here and there but its half a kilo here and there. so if you was able to get billet alloy suspension components made cheaply i think that would help greatly.
just yesterday we were talking to a bloke about 2 different shock brands (top brands) and he said one brand weighs 1/3rd of the weight of the other being a 8kg saving over all on one component. it depends at the end of the day how far you want to take it. i can see in your case its governed by rules but its just some info for you.
Thanks DJDrift - good info again. Yeh I've just been having the same discussion on suspension components (I gather it's the same brands you mention, as one was 1`/3rd the weight of the other, and I know that the "heavy" one is definitely very highly regarded.
I know the weight of the engine is pretty hard to control - and yes it's a heavy lump. Ideally, an SR20 Silvia is probably a more sensible choice (has already been homologated, and there are already a few running) but from what I am seeing, they will become very common, and I prefer to do something different.
Will definitely be tagging the cage to the shell wherever possible. That's pretty standard in my experience.
this may help as ive done most of thing weight reduction to a r33 gtst
r33 weights 1395 standard
i dropped 95kg by
changing front seats to sparco spit fires
removed rear seats and seat belts with bolts
spear tire and jack
lighter racing wheels
half the sound dentiner
carbon boot lid
removed rear wing
thats was 95kg
i still have a/c in, to keep in leagle u need the heating element for the demister but with the the cooling gear my workshop says there is 20kgs to be lost from behind the dash and the engine bay
and i still have a standard bonnet and standard steal guards.
my chrome olly 7 point cages weights 25kgs.
i think u can get the car to 1200kg with touching everything but it wont weight 1200 with u in and a full tank of fuel.
and thats were it starts with u in it and fuel.
best of luck
I tried to get to the weighbridge today but ran out of day, will try too this week for ya.
Mine is full trim minus power steering, which you definitely DO NOT NEED on dirt. The feel is f**king insane. I have 17x9+30, with rally wheels/tyres, the steering will be lighter.
Above listed weight loss and GTR guards and bonnet(or will you smash them? :)) would have you doing well.
a friend of mine was looking at building an r32. (well a few have talked about it) and it was decided that a r32 with the rb25de would be a better option because in my experiences turbos on dirt rally cars mean unfair restrictions within the rules. i Navigate in a NA bluebird and there is turbo blueies as well but they have such harsh rules to comply with. (thats my opinion of it any way) i think form the talk regarding the 25de. it could make more power, has more torque ect ect. they are nearly the same car but the biggest difference is they have 4 stud not 5 like the turbo model and single pot sliding calipers. im not sure if you could change the hubs withing the rules? the blueie i run in has a hilux rear end so maybe?
Regarding the brake topic earlier. you will fit r34gtt calipers and rotors under the stock rims and they are 30mm bigger rotors. same pad same look and cheapest bang for buck brake upgrade. thats if you even need it.
EDIT: you will be running 15" rims so im not sure on clearance.
the other real draw back of the r32 is the limited suspension travel. most people say they wouldnt have enough efficient travel for rally. the back end is the same as the s13 so if they are going ok than the back end must be ok but the issue is with the front end double wish bone setup. the S chassis car is different here and they can pick up more travel there.
anywho just some more food for thought.
Can you elaborate on that? 2WD PRC cars don't need to run a turbo restrictor (clearly stated in CAMS manual) - if that's what you're getting at.
I wouldn't entertain an RB25DE, as if I were going N/A route I'd be better off with a C110/C210 (or early Zed) with L28. With the knowledge base out there, a worked L28 will be better bang for bucks than RB25DE. Besides, a turbo engine makes such effortless, reliable torque, which is exactly what you want on the gravel.
Yeh, suspension travel might be an issue, but control arms are free, so might be able to custom fab longer arms for more travel - will have to have a good look at it.
I understand that there are some 15" rims that will fit over GTSt brakes, but not a hope in getting any to fit R33 or GTR brakes. That will probably be the buggest restriction. I have never needed massive brakes on a gravel car before - they are nowhere near as hard as brakes as a tarmac car, so I believe stock brakes will hold up well with decent pads and fluid (and some cooling ducts if necessary). Besides, I don't drive fast enough to need big brakes anyway :laugh:
My nav and I have lost a combined 30kg over the last couple of years, so there's a big weight saving already. The car weight is measured without a crew or helmets, and without fuel because the car can not weigh less than the minimum weight at any stage of the event.
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
