  • Replies 72
Posted Images
you can't look at a group a car for weight numbers. Fristly they had a pretty basic cage compard to todays standards, and things like most of the suspention being custom milled from alloy, and use of lightweight materails everywhere.
The GMS cars were pretty robust; they were the 1180kg cars. Bolt in caged NME/Jap cars at the 1115kg end. Very little custom milled alloy suspension in the R31s though they did run cast mag front uprights and heavily modified standard arms in the rear and tube front LCAs (can buy plenty of that stuff off the shelf for R32) . When you consider they were also running additional coolers and pumps for the diff, box, turbo, engine oils, full steel panels, an enormous fuel cooled ECU unit, onboard extinguisher, dry sump and pump, big turbo on an enormous steel manifold etc it doesn't seem that unrealistic to me.
And shaving 180kg isn't all that much (assume cage is 60kg), not compared to 265kg.
I think it's doable without going crazy. Remember mine was weighed at Targa at 1275, with all our safety gear (suits helmets etc) and nearly full of fuel. We aren't trying too hard, the car still has everything under the dash, climate motors, heater box etc.
There's plenty of weight that could come out of it if I was to spend some more time doing it.
ahhhh, i read in other places you said it was 1280kg, and i assumed 1280kg curb.
i think keeping the fan and heaterbox is worth it for rallys, when your in the car for ages, and driving with the windows down can make the notes fly around.
haha... r33 whales... good one... glavin!
ive stripped a shitload out of my r32 already... alot which wont be going back in... im up to 60 something kgs with more to weigh yet.
ive got the list at home but off the top of my head:
a/c compressor - 11kgs
a/c bracket - 3kgs
a/c condensor - 5kgs
heater box - 3kgs
a/c evaporator - 3kgs
fan blower - 3kgs
stripping wiring - 13kgs
front seats - 19kg each (replacing with 5kg each race buckets)
rear seat - 7kg
p/s pump bracket - 2kg
s14 p/s pump - 2kg over standard
s14 p/s rack - 3kg over standard
hicas lines, valves, rack - 15kg
rear wing - 10kg
thats over 100kg there.. and ive got alot more to go. thats all i can remember, ill make a list and put it in my build thread. plus most cars these days have an aftermarket exhaust which can weigh 20kgs less than the stocker.. add to that a lighter straight through exhaust and a dump and front pipe. the cast dump weighs a few kg, as does the cast exhaust manifold.
ive still got front guards, bonnet to weigh over gtr items, inner doors to trim, boot lid to replace, power windows to remove, sound deadening and carpet to weigh, more wiring to sift through, reos to trim, alot more weight saving ideas to think about.. plus getting what weight is left more centralised...
but im not looking to comply with race or rally rules, or rego if it comes to it, just a fun track day car.
so i think... if you are looking to comply with rules, and are looking to compete in a form of racing with some degree of comfort... then no, you will struggle to get it to sub 1300kg let alone 1200kg
if you are a retard like i am and think its fun to have a pointless waste of money that is unbearable to drive the 5 times a year you are able to drive it then yes, you may even get it down to 1100kg... as is what im aiming for.
Sub 1300? Explain mine then, 1275, with fuel and crew gear? Mine is completely streetable and (mostly) legal, has Brembos/power windows etc so it's not by any stretch a stripped cop. Mine's a 12/89 model, am I right thinking they're a little lighter to begin with than later ones?
Fark me you guys make things hard...just run more boost!
not all of us can run dirty truck turbo's :ph34r:
Ben: the series 1 doors are 10kg lighter each, i just got some for my car.
Edited by sav man
hahaha i read that... and then didnt even realise what you'd said. my bad. i usually count the "crew" in... as some have 1 crew, some have 2 crew, and sometimes 1 crew can make up 2 crew, so if you have 2 x 1 crew that = 2 crew, that = 4 crew. :P
i know you said crew gear....i mean crew... as in crew people that wear the crew gear. haha.
it has to be taken into account when talking about weights... as when your using the weight that is the car and crew gear... theres an extra blob sitting in the rhs that can add anywhere from 60kg to 120kg. sometimes theres 2 blobs.
so your car is 1225 dry... 1280 wet... how much with you and your navigator slinging around corners??
this has got me keen to weigh my car, i have been meaning to do it since i finished it, i have removed everything mentioned and alot more, and am about 60kg lighter in the front end due to the donk, so im hoping 1100kg.
apparantly (meaning i actually have no idea) this bad boy does a 1:1.7 around tsukuba
weighs just over 1000kg, rb25 turbo on rb20, 310ps.
there is more info around page 140ish in the r32 photography section.
i saw that in a option mag. from the little bit of english it runs a 1:01.xx, and is a RB20 with a 25 turbo. But I couldn't read a weight.
From the pics it's been extensivly stripped and speed holed, and those bolt in jap cages are light as.
Edited by sav man
Ok cool. I thought we were talking about fixed weights of the actual cars, as crew weight of course always vary. I'm around 90kg and Tim needs to go on a diet to offset me, he's about 70kg I think?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
