Nah my OP was without crew or helmets or fuel.
Tha CAMS regs state:
The weight is the real weight of the car, without driver nor co-driver nor their equipment; this
includes the helmet, but the headphones external to the helmet may be left in the car.
At no time during the event may a car weigh less than the minimum weight stated in this article
ie min weight does NOT include driver, helmets etc. External headsets may be left in the car for this weight measurement, but as the car must always exceed this weight, then it has to be measured with no fuel, or at least the minimum fuel load you are ever going to run.
Total weight of co-driver and driver is less than 145kg, so not a significant amount to add into the car to upset balance.
Having said all that, looks like we'll struggle to get the dressed weight anywhere near the class minimum (1180kg), given the reinfoecement and heavy duty gear we'll need to be running (light weight suspension components don't fill me with confidence if the car will be spending time with all 4 wheels off the ground)
Next weight category (sub 1260) will let us run up up to 2.35L. Looks like the best option is to use the RB26 crank with max allowable overbore (1.5mm) to give 2.2L. Probably big $$ for a 10% capacity increase.
But I'm getting way ahead of myself now :D
  • Replies 72
Posted Images
weighed mine today, it went 1193kg with 20ltr fuel. Heavyier than i thought by 100kg.
But I'm getting way ahead of myself now :(
yeh basic lighting and engine loom only. i dont think there is much more that could come out, i didnt realise r32 went 1400kg so i guess loosing 200kg isnt too bad, but getting one down to 1200kg with an iron block would be a great effort, and gtr with 4wd id say impossible, but correct me if im wrong.
yeah good result stu. it is pretty well stripped including most of the wiring too right?
ive posted this list before from when i stripped my r32 gtr but most of the stuff would be the same as a gtst im sure...
rear seat back 6.5kg
rear seat bottom 6.5kg
front ds seat 15kg (keeping this)
front ps seat 15kg
main carpet 6kg
rear trims in back seat 5kg
parcel shelf 1kg
space saver wheel 15kg
boot trims 6kg
jack/toolkit 4kg
boot brackets 3kg
air con/heater/blower fan 10kg
firewall sound deadener 4kg
rear seat belts 2.5kg
spoiler 7.5kg
air con pump 8kg
air con bracket 1.5kg
charcoal canister/bracket 1kg
washer bottle 1kg
hicas pump, engine bay lines 7kg
abs unit 8kg
hicas undercar lines 2kg
cooler piping/bov's 15kg
fusebox loom 7kg
front bumper support 6.5kg
sound deadener 11kg
dash loom 4kg
fuel tank 13kg (fuel cell = 6kg)
interior/attessa/boot loom 6kg
rear wiper motor 2kg
coilovers 6kg lighter than stock
hicas pump rack 9kg
boot with spoiler (no hinges) 15.5kg
total 208kg so far
front axles x 2 12kg
sump/front diff(gtr=24kg, vl=2.5kg) 21.5kg
air con condensor/lines 5kg
battery 15kg
wiring harnesses 8kg
drum brake assemblies 5kg
hicas ecu 2kg
heater hoses 1kg
bumper reinforcements 8kg
transfer case 33kg
oil cooler block 2kg
total of stuff to go 114.5kg
1460kg-314.5kg = 1145.5kg
gtr box 89kg
gtst box 56kg
rollcage 67kg roughly (CDS andra/cams approved full cage with additional barwork)
Then add in what you are going to put in like big brakes, oil coolers etc and you can get an idea.
Edited by unique1
if you were getting down to that sort of weight, the standard brakes would near do the job with good pads and rotors... any more brakes and youd just lock up..
are the dba 5000 alloy hat rotors much lighter than teh stockers??
btw, gtst seats are 20kg a piece. weighed mine on the weekend.
can anyome confirm for real about the early and late doors being 10kg different?? does anyone know why?? mine is a 94 model and they are heavy... i was gonna take to em with the grinder but if i can just get early model doors that would be sweet.
I'm 99% sure GTR and GTST doors are the same, ie the series 1 doors are much lighter (no intrusion bars). Could you look into removing the bars from a later model door?
BTW yes the alloy hat DBA5000 rotors are significantly lighter. I don't have the exact weights but it is very noticeable.
We looked into getting carbon doors for the race car but after cutting the intrusion bars out and alot of the metal from behind the trim and then relining it with a flat piece of alloy we didn't think a carbon door would be much if at all lighter. We also don't have windows either so we save alot of weight there too.
is there any structural loss wih removing door material?? to the door itself, like sagging etc.
i cant imagine so as they are pillarless, and with the cage, you should be able to run without doors.
wrx 5000 series rotors are 5.8kg each. imagine skylines the same.
Correct. When I got T-boned (92 GTSt) the replacement door they sent me was from a Ser 1, without the intrusion bar. I asked the panel beater to swap the intrusion bar over, and he said it was a massive structure, weighed a tonne and was a huge job. We didn't weigh the gear, but it had a significant effect on door weight.
The intrusion bar would likely have next to no effect on rigidity of the door in terms of sag etc, but the added weight would likely cause hinges to wear out quicker.
Interestingly enough, when he spoke to the insurance company about whether they would cover the cost of this, their response was to notify them if my existing door didn't have
the intrusion bar, as this meant they would cancel my insurance policy.
If you had a decent cage with intrusion bars then that negates the need for the door bars, although every little bit helps, and even if the door slows your car (or the car hitting you) by 10km/h, then that could be the difference between life and death.
I am considering removing the heavy intrusion bar, and fitting a lighter RHS bar in there - even if it only loses a couple of kg, but retains (or increases) the strength of the door, it can't be a bad thing
BerserkR32 - if you could point me in the direction of one of these light weight alloy RB engines, I'd be grateful. Were they homologated? :(
how much weight will i lose if i bore the block out?? hahahaha.
i think in my situation, the intrusion bars can make their way to the scrap bin, the car will be lucky to see sun 5 times a year.
the said doors that ben has now were on my car. i did some experimenting and found that 80% of the weight of either door is within the metal of the door especialy around the hinging area.
i cut every bit of the inside of the door i could and it made maybe 1kg difference for a loss of rigidity so my conclusion was dont bother hacking the light weight doors at all.
the glass and the window reg weigh f all and you would be lucky to have the weight of the glass when using perspex. we have perspex in one of the race cars and its a pain in the ass.
my conclusion is. if you want safe. stic with the s2 doors. if you want light and practical ie window working use the s2 door but dont cut it or if your going all ou then get carbon of fibre glass doors. they arent that dear for the advantage. ive seen them advertised at under 10kg each so thats 30 odd kg a door and thats a big number for a small part of the car.
oh and ben now were back on the light door topic i want them back :D
I got a set of gtr doors at home, 32kg, they still have most of the bits inside. minus the outer interior skins/trims
you could easily get them down to 20 something by removing motors and adding winders or something and cutting a bit
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
