Hello,
Recently purchased a gtr32 for a bit of fun. It has a shuttering that goes through the whole car when turning left only and only occurs at low speeds (around less than 20kph). Turning right at any speed is fine as is turning left above ~20kph.
Any help would be appreciated.
Thanks,
Andrew
Edited by RedEmblem
Well the only thing I can think of that could cause a shuddering is maybe a wheel bearing, something to do with power steering, something is loose or something is rubbing against something when turning. Now I'm not sure why it would only be doing it when turning left and not right if it were a wheel bearing. But I'm just throwing up some ideas for other people to maybe comment on.
mine does the same thing with im havign problems with the ATTESSA AWD system, only at low speed, turing out of a park space ect, but mine is both sides, im pretty sure. and the same shuddering.
does you SLIP light come on when its happening?
Edited by sydking
  • 4 weeks later...
  • 1 month later...
What about at higher speeds?
My 32GTR shudders around corners at higher speeds - it feels like it is happening when the front wheels/diff is getting power...? it doesn't feel like this is how the 4WD should work?
Sorry if this is a stupid question - it's my first GTR and I haven't had a chance to get a mechanic to look at the 4WD.
I have had this before with the R32 gtr diff - certain oil will make it really tight, so very low speed cornering it locks, and then causes the shudder.
Mine with redline lightweight shockproof was so tight it would actually refuse to move - dropped the oil, put some redline gear oil 80W140 and problem pretty much gone - one more flush and it would be gone completely as this is what I was using before the shockproof went in and no problems then.
Andy - I also used to get it happening slightly at higher speeds as well until I changed the oil.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
