  • Replies 246
Posted Images
thanks again.....
Lincoln Precision Tig 225, not a inverter style machine.
is there a problem with the inverter machines? Just curious (I only have a cheapy DC TIG - no good for alloy - and I use it from time to time when my stick welding letm me down)
Nice work there, too.
Like you say, welding is not something you can just pick up and retain without doing a lot of it (and knowing what settings to use in different conditions). You need to practice, practice, practicce. SOmething that frustrates the hell of casual welders such as myself. :)
I have had a bad experience with 3 different ones over the past year or so, so I went with a transformer machine, which considering how long they have been around for, I hope this one lasts. Thats not to say inverter ones are good, but they seem more prone to having problems.
Haven't had a problem yet with this one and I have used it every weekend for the past couple of months.
Edited by ISL33P
thanks....luckily it doesn't cramp up because I don't know what I wil do. I love fabricating my own bits 'n pieces and then welding it. There is something about the custom/raw look that I have always liked and wanted spread out all over my car.
One thing I have to learn how to do better it complete those long runs on the plenum all at once, and that's got to do with the way I move my arm, but that will come with more practice.
thanks Ben.
Duncan - this is a generic length for the rb30/vl engine bay but they can be all customised which is usually dictated by a couple of factors, mainly cam duration and peak torque range.
hahaha...anytime you like :)
on a side note, do you now anywehre local, as in Oz, which will have around 4 or more vh's lying around?
looks like there will be some serious amount of vh turbo goodness happening around Wollongong way :)
Nah, afraid not... A guy named James in Sydney fiddles with them. I bought two off him a few years ago. Last I heard he had a mental NA VH45 in the build. I believe his company is called Protune now. Young guy, probably about 21 now, he might have some spares or know where to get some.
Back to serious business, what do you need to make a low plenum for the VH? I have a whole spare motor here, but I'm not keen to ship it around for the fun of it. I'm modding my standard bonnet to fit the standard plenum and throttle, but I'm not sure what will happen if I get defected. Technically the bonnet supports will be cut (a big no-no in QLD), but rewelded, so may be a issue later on.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
