  • Replies 246
Posted Images
I always use 5, I have used 4 in the past but never really liked it. What are your thoughts on the 4?
I will have some more pics up in a couple of days of the welding I done on the weekend....more of the cast to raw aluminium and it turned out quite well and consistent which is most important.
i really only use 5356 which i have had no problems with it, but i havent tried pipe/cast or sheet/cast with it.
ive used 4043 before but thats only good for cast repair,
i might grab 1kg of 4047 and compare it to the 5 series
Silly question, would you know if the RB20, RB20 or Rb26 fuel rails are interchangeable? I have an RB26 rail for my RB20 and after having a quick look at it i suspect its not going to work....despite my mates assurance he ran a scummy RB20 rail on his RB26.
One other thing, is there a reason why the runners are perpindicular to the plenum when you are going full custom?
For some reason I believe they do but not 100% sure since I usually make my own. I would just see if anyone else can confirm, I think the rb25's are not.
This has been proven over and over to produce the best results in terms of flow and consistency between runners with a correctly designed plenum.
looks great! just curious, how you manage to get the torch into tight spots like this? do you pull the tungsten out a fair bit, and wind up the gas flow to shield it more? or any secrets? :D
i'm also thinking for tighter spots too, like between runners in an ex manifold, etc..
I use a 20 size torch....being watercooled it is a lot smaller than the air cooler ones.
I have very rarely needed to extended the tungsten out of the cup or turn the gas flow up when welding aluminium....I usually just crank the amps up. I do though for stainless/mild steel and tight spots.
They are sandblasted prior to welding. If they are not blasted and you try to weld them, the impurities should only come from the cast and not from the oil on the inside of the runners. If that's what's happening you are using to much amps.
I used to weld them before blasting them but as you can see the result is just fine doing it before and this justifies not having to blast them afterwards as well.
You could ask what type of sand I use to blast them, but then I would be giving away all my little secrets :P
Ariel
hahaha fair enough :D
well its either soda or glass bead - as no garnet/crushed glass/oxide based blasting media will give that shine :)
you've given me enough hints so i should work the rest out myself :D cheers Ariel.
Chris
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
